New member - nut size question and brake master cylinder
Hi all,
I've just joined the forum but I've been reading lots of posts as a guest, following my purchase of a Metallic Blue 1967 Plus 2 with a Zetec conversion which needs recommissioning.
I was hoping to get it up and running before posting but want to check the size of the seat rail bolts, I think they're supposed to be 1/4" UNF (I'd seen them referred in another post) but when I try them, they're a really tight fit in the captive nuts that have been glassed in.
Would rather ask the Oracle than strip, or worse, loosen the captive nuts, can anyone confirm?
Also, I've seen a post about removing the pedal box if needing to overhaul or replace the brake master cylinder, is that the best recommendation or should it be easy enough to disconnect the linkage and pull it the cylinder out from the back of the box, I don't have any carpets in there at the moment so a few drips are easily cleaned up?
Cheers for any assistance you can provide, will get some pix up when I've got the car on the road.
Darren
Darren
- autopia
Darren
It helps if you fit an access plate on the top of the pedal box and is easier if you are double jointed,but yes you can remove the master cylinder from within the engine bay.
Hi Darren and welcome.
Obviously this isn't going to cover any non original parts but the Parts manual has all the part numbers for each nut and bolt and in the front there is a'translation' of what all the numbers and letters mean. Head type, Bolt length, thread/nut size etc etc
elanfan1 - Coveted Fifth Gear
... and there's a parts manual to view on line here, http://rdent.com/manuals/index.html . Ray, at R. D. Enterprises Ltd, is a stateside supplier of all (most) things Lotus and an all round good guy to work with.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:... and there's a parts manual to view on line here, http://rdent.com/manuals/index.html . Ray, at R. D. Enterprises Ltd, is a stateside supplier of all (most) things Lotus and an all round good guy to work with.
People keep referenceing the R Dent copies, but did you not know that the parts lists are HERE too on this website, in the unfinished Wiki section.
Here is the Plus 2 parts list.
http://www.lotuselan.net/wiki/Category: ... Parts_List
Thanks for that Bill. I hadn't really tried the Wiki in awhile. It's coming along nicely.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Hi all,
Many thanks for the welcomes and your advice/answers, 1/4" UNC makes sense, the UNF are not going to go in so no point in forcing, will pick some UNC's tomorrow.
Also, I cut a panel out above the BMC, need to fabricate a cover, but it was so much easier than trying to get it from below, I didn't want to remove the pedal box as it's all mastic'ed in.
Will get around to posting some pix when I get chance.
Darren
Darren
- autopia
