Front Spring length for +2
As the list title, what size front springs & rate to fit to Gaz adjustable platform units. I fitted 11" free length 140ibs springs but to get the correct ride height I have wound up the platforms, the impact of this is the springs are too close together so can't operate & bottom out! All help & ideas welcome. I did try to find specs before I fitted these units. (
White +2s, S4 in bits & the practical Honda!
- therolfie
Ok so rung a couple of the usual suppliers today.
One suggested an free length of 9" & 175ibs
The other free length 12" & 150ibs
The original for the plus two was 14" & 110ibs
I will wait to see if people have experience with a good set up.
Thanks for any feedback of plus two use.
- therolfie
mmmmm.... looks like most of the suppliers don't understand much about design of springs. i assume you want the same installed length as the original springs ? If that is the case then the next question is what style of spring you want.
regards
regards
Hi Rohan
I have GAZ shocks with adjustable platforms & in time will convert the rear to adjustable. I'm after a fast road car set up, but yes I want to be able to drive it without my teeth falling out! I have measured the gap whilst the car was jacked up & the platforms unwound. This was 27cms or about 10 1/2". Any thoughts? Thanks
- therolfie
The Plus 2 with its wider track and higher standard spring rate is much more suited to modern sticky tyres than the Elan. I run mine on the standard setup with Yokohama 165 x 13 / 60 A048R track day tyres for road use and find it fine with no real need to harden it up.
If I was going to set it up harder I would try around 140 lb/in front and 120 lb/in rears as a first step. I would probably also go up from the standard 3/4inch (19mm) front roll bar to 21 mm. All this make the handling a little sharper without making it so hard as to be uncomfortable on normal roads
Free length for same ride height with standard platform position would be 12.7 inch for fronts and
Free length for the rears would 14.3 inch. Installed length for these springs would be the same as the originals i.e. 8.6 inch front and rear
When fitting stiffer springs especially the fronts on a Plus 2 you always need to check coil bind height and ensure the shock hits the bump rubber before the coils bind. Most Plus 2 springs designs are very highly stressed so you need to buy top quality springs preferably "hot wound" to avoid rapid sagging of the suspension due to the front coil collapsing under stress.
If going to smaller diameter rear springs and the orginal Aeon rubber spring does not fit find an equivalent rubber spring that fits and fit the spacer like the later Plus 2 had.
Please shoot me down if I am wrong as this is something I have been trying to get straight for a while.
According to the manual the front spring is 14.19 / 8.6 Free / fitted. A the initial poster stated.
So this would give a preload of 14.19 - 8.6 X 110 lbs = 559lbs.
A 11in free length, fitted between the same damper seats would only give 11 - 8.6 (2.4) X 140 = 336 lbs.
To get a 559 lb preload the lower seat would have to be raised to compress a 140 lb spring 3.99 inches.
3.99 - 2.4 = an extra 1.59 inches. I. e. - most of the adjustment
OR to get the same preload, with a 140lb spring, it would need a free length of 12.59 inches.
Is this relevant??
Is this relevant??
- vincereynard
vincereynard wrote:Please shoot me down if I am wrong as this is something I have been trying to get straight for a while.
Is this relevant??
Yes you are correct with the calculations and this is the problem with the original 11 inch free length springs fitted.
It had to happen sometime!
So before changing springs etc, the distance between the damper spring seats on the, fully extended, existing damper should be measured / established.
Which, presumably, should be the 8.6 > 9.0 inches mentioned in the workshop manual.
This can then be used to discover whether a prospective replacement will be suitable.
One mod at a time?
- vincereynard
One mod at a time?
The 8.6 inches is the spring length at norrnal ride height, not at full suspension droop. You need to make sure the free length is greater than the full droop length to avoid the springs coming loose on full travel. This is not normally an issue with Elan or Plus 2 Front springs unless you have really hard full race setup.
This is not clear for me, 14,19 minus 8,6 should be 5,59 compressed length * 110lbs = 614,9lbs
So in my view the preload is 614,9 and not 559lbs.
Someone of us is wrong but Rohan has confirmed your post, seems that i've made the mistake but i couldn't find it please let me know where it is...
Mario
- 1972 Lotus Elan Sprint LHD/DHC
- 1962 Austin Healey Sprite MK II - Sold 09.05.2016
Sorry for my bad survival English
mariodschy - Second Gear
I thought it was too good to be true. Mental multiplied by 100 instead of 110.
And I've just finished a biography of Isaac Newton. My apologies.
Vince
- vincereynard
vincereynard wrote:I thought it was too good to be true. Mental multiplied by 100 instead of 110.
Vince
Now it's clear where the 559 come from
Thanks for all the replies ) I have fitted some old standard shocks with springs for now. Need the car for my wedding this weekend so priority is getting the interior done! Will be back in touch soon. Thanks again
- therolfie
