Thickness of +2 rear strut tube
PostPost by: david.g.chapman » Tue Nov 10, 2015 2:49 pm
Does anyone know this? I had a look at the posts but could not find a figure, or a picture to help.
Everything is assembled so I can't see for myself.
Dave Chapman.
david.g.chapman
PostPost by: john.p.clegg » Tue Nov 10, 2015 3:47 pm
Dave
OD. 1.996" ( 50.72mm)
ID. 1.865" ( 47.37mm)
Wall 0.1" ( 2.55mm)
All figures approx...
John :wink:
PostPost by: lotusfan » Tue Nov 10, 2015 4:45 pm
I think your abacus may be faulty, thickness is 0.065 inch (1.66 mm)
72 Sprint DHC
lotusfan
PostPost by: john.p.clegg » Tue Nov 10, 2015 8:56 pm
You could be right,it was done in the dark under the bench,the figures don't add up,will re-calculate...
John :wink:
Edit
Second attempt
OD 50.78mm 1.999"
ID 47.1mm 1.86"
Wall 2.17mm 0,085"
PostPost by: david.g.chapman » Tue Nov 10, 2015 10:36 pm
Thanks John and Mike,
I had some surface corrosion on the inside of the tube when I removed a caliper shield. Looks like there is plenty left in that area.
I had to grind off the three remaining nuts on the shield that were solidly seized on the captive screws. Even Plus Gas would not shift them.
I will grind off what's left and make new slotted holes for a new 4 off screw and nut combination on the lower and upper parts of the shield.
Dave.
david.g.chapman
Users browsing this forum: jebracing and 13 guests
