front spring/shock assembly
just pulled my front assembly apart with the help of this forums' brilliant members.
I've found rubber washers at the top and bottom of the spring, they fit between the spring and the shocker perch/collet. Is this normal?
I also have flat rubber wrapped around the body of the shock..is that normal?
cheers,
-Jim
cheers,
-Jim
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
I don't recall rubber between the spring and the collet although it's a while ago now since I did the job. There was a rubber sheath on the damper body though, I assume it was to stop noise of the spring rubbing on the body.
UAB807F - Fourth Gear
