Plus 2 front vertical links
PostPost by: rmorgan12 » Fri Jun 19, 2015 4:13 pm
My previous thread read,
**********Are the front vertical links on a +2 the same as a Mk 1 Spitfire/Herald (they look exactly the same)or is it only the GT6's that fit. I see their is a set on ebay which look exactly the same but I'm not quite sure. I thought I remember reading a similar thread that the size of the stub axle taper might be different?*********
I've now learned that it's the GT6 vertical links that fit, not Herald/Spitfire.
Having looked on line can I also assume that the ones off the Elite/Eclat are the same aswell.
Cheers Rich
Elan Plus 2S 130/5
rmorgan12
First Gear
First Gear
PostPost by: Peter +2 » Fri Jun 19, 2015 6:16 pm
Rich
GT6 uprights are the correct ones for the +2, but I cant help with Elite or Eclat.
Sorry
Peter
1968 +2 BRM
Peter +2
PostPost by: Vic » Fri Jun 19, 2015 7:25 pm
Yes, my 1979 Eclat used the GT6 uprights. Bolt pattern on the Eclat was 4 on 4.5 inch, so hubs are unique, but uprights are GT6.
Vic
Vic
PostPost by: Vic » Fri Jun 19, 2015 9:05 pm
I should mention, there is a company that makes adapter spindles that would work to fit GT6 hubs onto Spitfire/Herold uprights. With these, you don't have to change the upright, just the spindle, when switching to pin-dirve/knock off hubs.
http://diskhero.com/prirace/spitfire-hub.asp
Vic
PostPost by: rmorgan12 » Fri Jun 19, 2015 9:33 pm
Thanks Guy's
Lotusbits have got lots of Eclat/Elite 2nd hand Vertical links with Trunnions.
Cheers Rich
Elan Plus 2S 130/5
rmorgan12
First Gear
First Gear
PostPost by: rmorgan12 » Wed Jul 01, 2015 7:17 pm
I've just received the Eclat/Elite vertical link and Trunnion from Lotusbits and it is exactly the same as the Plus 2.
There is no slack in the thread and seems to be in good order although very grimy. At ?30 it's good value for money and because they're old, hopefully won't suffer with the problems associated with the new Vertical links i.e.. snapping at the top thread
Thank you to all who replied to my post.
Cheers Rich
Elan Plus 2S 130/5
rmorgan12
First Gear
First Gear
Users browsing this forum: No registered users and 46 guests
