Front Vertical Links +2
Are the front vertical links on a +2 the same as a Mk 1 Spitfire/Herald (they look exactly the same)or is it only the GT6's that fit. I see their is a set on ebay which look exactly the same but I'm not quite sure. I thought I remember reading a similar thread that the size of the stub axle taper might be different?
Cheers Rich
Cheers Rich
Elan Plus 2S 130/5
- rmorgan12
hi ,
look at the steering arm, plus 2 elans use gt6/vittesse , arm and upright, the spitfire one is quite differant,sorry cant post pictures , but look sat canley classics website , for referance
regards
mark
regards
mark
- Mark plus 2 cabby
The early Spitfire ones - like the ones pictures on Ebay - are identical. They have the same Lotus part number. Back in the late 1970s, I replaced a vertical link and stub axle in my Europa, and the local import dealer had these Triumph Spitfire parts in stock.
FWIW, the GT6 stub axles are the ones that are beefier and do not fit. HTH.
Steve in Ohio
Steve in Ohio
- sveris
Users browsing this forum: No registered users and 41 guests
