Ride height is too low
Without going into a longwinded story has anyone any ideas on this?
A few months ago I "crunched" the front wheelarch lip when turning into my drive (at a walking pace incidentally). The tyre had obviously contacted the return lip on the arch producing a 3 inch long crack.
I've owned this car 37 plus years and this is the first time this has happened.
Assuming the obvious to be the cause I changed the front springs for the std 85lb units (to replace the 20 year old std 85lb ones on the car). Result- no difference in the ride height or clearance.
Some info about the car-
Std fhc sprint- no body mods.
Std suspension
Std size tyres - 155/80/13
Original engine so no weight changes
To be honest I've never really paid any attention to the wheelarch clearance before although thinking back I seem to recall casually thinking that the car seemed to low ride but unfortunately I've no old pictures showing the clearance back then for comparison.
I did notice when I bought the car in 1978 that there were cracks in both front arches but put this down to carelessness by the first owner when removing the wheels but maybe he'd had a similar problem.
The body sits correctly on the chassis so I've ruled that out (the chassis is not recent so can be discounted and it's properly bolted on).
Any ideas- the only thing I can think of is a mis-shapen body but looking at other sprints I can't see any noticeable differences.
I've attached a picture I took today for illustration- I reckon the lip should be around an inch higher.
- worzel
Do you have the proper spacers between the chassis and the body? My Elan had spacers on the front and the rear of the chassis.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
You normally only need spacers where body not straight and does not sit right on all the chassis points. They were not a normal factory fitting.
The front arches will normally hit in the situation you describe - just need be careful going into drives ( or full opposite look on the track ))
I stand corrected. Was wondering why the spacers where there. Thought it was for body height adjustment.
Glen
Certified Lotus wrote:I stand corrected. Was wondering why the spacers where there. Thought it was for body height adjustment.
On my car, when fitting the TTR chassis, I did use spacers for body height adjustment. The whole chassis was assembled, complete with drivetrain. Then the body was lowered onto the chassis, and spacers were used in the front to obtain proper bonnet clearance. Transfer punches were then used to mark the chassis for drilling.
- elancoupe
What is the measured ground clearance?
Many elans look higher as they have adjustable dampers which move the bottom spring platform up and/or the later spec springs which are longer. Thereby increasing the ride height.
You are in the lucky position, that to increase the ride height you just add a spacer under the spring - Most people are trying to reduce the height at the front!
Regarding shim washers - The manual does list them, but they are as required when you have a gap between the body and the chassis so that you don't bend things.
- AHM
Thanks for all of your responses.
spacers- hmmm- when I changed the frame a few years ago I'm pretty sure there weren't any on the car. The front fitted snugly against the tops of the front towers and ahead of the steering rack so I assumed that it was correct. I do remember however that at the back I needed a spacer just behind the bottom of the axle.
If in fact it is a problem of omitted spacers it's obviously a bit late to start thinking of retro fitting any because the tapped holes won't be in the right places in the front towers so it looks like it might be a case of modifying the springing to raise the front.
Any idea if there are any off the shelf springs that might do the trick- I'd prefer to retain the koni dampers rather than use adjustable platforms although I realise I might be forced to modify.
- worzel
Hi - again
In reply to AHM-your posting came up after I sent my last response so didn't take account of that.
Ride height- I've not checked- yet but will do so.
You mention shims to fit under the spring- would I be correct in thinking they fit at the bottom around the damper body since this presents a flat plane and- are these available or is it a case of having some made?
Regards and thanks
Regards and thanks
- worzel
If you measure the ride height under the body when it is flat just in front of the rear tires and in back of the front tires, on both sides, that would be helpful in determining how much it needs to raised. My s4 has adjustable front and back, but you could use shims with the standard. My ride height is 6" at all 4 spots, and I have no issues despite a particularly bad driveway with a hill and a tight turn. Dan
John,
It is a case of having them made - you need a friend with a lathe.
Read up on here about ride height being too high, for the different spring lengths and the ratio between spring length/ride height.
But as other have said check everything first. You probably have the only car that is the correct height.
- AHM
Hi- Cusword
Re your comments about the minilites- I fitted them about 6 years ago. They are fitted with the std 155/80/13 tyres. Since the rims are 5 inch crows section effectively the tyres are slightly lower profile as they are stretched more across the greater width so clearance is actually slighter greater. As for the offset I guarantee it is correct.
I think I'll first try the suggestion about the top mounting rubbers (simple and low cost) as I can see how soggy rubbers would "drop" the body relative to the tyres.
I'll let you know as it must surely be a common problem.
- worzel
