axle to hub fit
PostPost by: bulfin » Fri Jun 12, 2015 1:07 pm
Shouldn't the axle end (not the threads) be flush with inside of the hub? After heating the hub and using a 12 ton press, mine are still 1/16" away from being flush when it would not move further. I guess I can apply more heat and pressure if it should be flush.
Bob Bulfin
1969 Elan S4 DHC
Mobile, AL USA
bulfin
PostPost by: rgh0 » Fri Jun 12, 2015 1:13 pm
No it is not supposed to be flush - you pull the hub on with the axle nut and ifs flush it stops pulling ! you do not need to press it on. Just lap the fit between the hub and shaft taper then bolt it up to the specified torque
The taper fit on the hub does not need a large amount of pressure to fit it. With a 12 tonne press pushing it on you may never get it off again !
PostPost by: bulfin » Fri Jun 12, 2015 5:11 pm
Rohan,
Thanks again for good advice. I will leave it be until I put it on the car.
Bob
PS: I hope I never have to take it off, but it is a Lotus :D
Bob Bulfin
1969 Elan S4 DHC
Mobile, AL USA
bulfin
Users browsing this forum: No registered users and 45 guests
