Rear bearing play ?
Hi , I had a problem with the rear knock on spinner coming loose which I thought was probably down to inadequate tightening and the fact the threads were not completely clean , so now it's tight and clean. However there is a small amount of play which I think comes from the bearings. Page 8 section G of the manual quotes a maximum of 1.27mm under wobble.
This seems quite a lot if it refers to movement in the bearings , or am I misunderstanding where the wobble originates.
Btw on the other side there is no play or wobble.
- Concrete-crusher
Concrete-crusher wrote:Hi , I had a problem with the rear knock on spinner coming loose which I thought was probably down to inadequate tightening and the fact the threads were not completely clean , so now it's tight and clean. However there is a small amount of play which I think comes from the bearings. Page 8 section G of the manual quotes a maximum of 1.27mm under wobble.
The wobble the manual quotes is total run-out of the wheel mounted on the hub. Bearing play should contribute nothing to this and you should not be able to feel any movement in the rear hub bearings. Any movement is normally a bearing on the way out or the bearing loose in the alloy housing.
