Dyna Beads? (or Counteract)
PostPost by: oldchieft » Sun May 17, 2015 4:25 pm
Has anyone seen the crap stick on and quickly fall off lead free balance weights?
I wondered what experience members have had with in-tyre beads?
Jon the Chief
oldchieft
PostPost by: Chancer » Mon May 18, 2015 10:21 am
The principle is good but a load of water or tyre repair goo washing around will also dynamically balance above certain revs but if it hits the resonant frequency of the suspension at below that then its like a tank slapper on a motorbike or trailer weave, you need to go faster but do you have the balls?
My commercial washing machine has a coaxial drum with water or some other fluid sloshing around Inside it, at first I thought it was broken, it will balance a dramatically unbalance load as long as while climbing through the lower speeds the shakes dont activate the inertia sensors.
Chancer
Users browsing this forum: No registered users and 44 guests
