Pulling a Bolt-on Hub
I am about to replace the original front rotors on my 1965 S1.5 and see that the lip of the front hub is curved and would likely not permit a hub puller to grip it there. What have you used successfully? I realize that the hub may come off with mild persuasion with a rubber mallet, but given its age, it may be more challenging.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
Hi I'm assuming you are removing the front brake discs from the hubs , I did mine recently , and once the castellated nut is undone they freely come off.
Sorry if I have not understood what your removing.
- Concrete-crusher
Steve, yes, front hubs. Will hope mine come off as yours did. Thank you.
CG901 - Second Gear
