servo
Hi George
Are talking about the filter or the check valve in the vacuum line?
Graeme
Graeme
LOTUS Evora 400
Ginetta G27 S2
66 one-off 2.6Ltr v8 Mid-engine Berlinetta Coupe........... in restoration
..................................................Age doesn't matter unless you are a cheese................................................
Ginetta G27 S2
- au-yt
Thanks for reply Greame dont have a check valve in line just been working on brakes with the servo vacuum line disconnected brakes work but not as effective with line connected brakes are slow to operate and slow to release as though the servo is sticking.It,s a new servo,lockheed type.I,ve checked and i can hear air valve operating and i,m now at a loss as to what to try next.
thanks
George
thanks
George
- gsl
This is quite useful to explain the workings of a Lockheed servo ( even though its fitted to an MGB)
http://www.v8register.net/FilesV8WN/Bra ... 190109.pdf
There is no need for another non return valve in the suction pipe if the servo has one (which most servo's do)
The brass right angled fitting fitted by Lotus to the manifold has no valve in the servo take off pipe as that is straight through, the other take off pipe to the headlights does have a one way valve in it.
billwill wrote:Your problem may be caused by the abscence of a non-return valve in the suction pipe from the engine input throat.
Or it could just be new.
Pete.
http://www.petetaylor.org.uk
Pete.
When I had my booster overhauled last month they could not get a a check valve, white plug in connection to the booster so they gave me an inline one and that works, if that's of assistance.
Graeme
Graeme
LOTUS Evora 400
Ginetta G27 S2
Ginetta G27 S2
- au-yt
Users browsing this forum: No registered users and 41 guests
