Rear bump stops
Hi all
Has anybody fit powerflex bump stops?
I am re building the rear suspension and the new bumps stops won't go onto the the new strut.The struts are tony Thompson. Do I have the force them on?
I have measured the dia of the strut and it's about 22mm and the bump stop is 20.2
Any photos would be most grateful
Cheers ian
Cheers ian
- thorbs000
The original Aeon rubber springs are more than just bump stops and are an integral part of the suspension design. I believe they are now available again ( contact Jeff at JAE). I would use these rather than the ones you show that don't fit.
Ian,
Just force them on, I believe some people use two sets to reflect the original bump stops length, I do not know if its necessary and I just stuck with the one set that TT supplies.
As per Rohan's suggestion I was going to use the original bump stops but i found they would note fit the 2.25 TT springs.
Peter
Peter
1968 +2 BRM
- Peter +2
