Lock Nuts for Front Suspension
I believe R.D. Enterprises carried them, but I don't see them on the website any more. I think I bought a set of them, but they stripped pretty easily.
McMaster-Carr is a good bet: http://www.mcmaster.com/#hex-locknuts/=p2stks
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
Ray has half nuts, which work fine. They leave room for a washer.
Dan
Hmmm.... maybe I should re-word that so as not to offend Ray.
Ray stocks half nuts, which work fine.
Dan
I think they are referred to as P type in the UK the lower Nylocks think they are 1/2 inch UNF from memory
Ian
Ian
- elansprint
I got mine from McMaster Carr. Their part number 94945A225, $6.47 for 5. Grade 8, 1/2-20.
Leaves plenty of room for an SAE washer.
(Please disregard the dust. There's body work going on in the background.)
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Aircraft spruce and specialty
Aircraftspruce.com
Coast fabrication
Coastfab.com
I have yet to find a piece of hardware that Fastenal could not supply. I have used them for big marine applications and AC&R work for years. Great products, and good counter service. They are a bit more expensive than McMaster but in my experience they have always been worth it.
Will
Will
-Will
26/5175
26/5175
- ensign42
Agree that Fastenal is great. I had forgot about them.
Their branches are located in most cities, usually in industrial areas they serve.
reb53 wrote:You need a friend with a lathe.....
Ralph.
. . . or a bench grinder!
'67 S3 SE FHC
'67 S3 SE FHC
...for ten bucks?
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Hi Gale
Also check w. Olander Co. in Sunnyvale.
Phil
1968 S4/SE FHC 36-7936
- pamitchell
I don't know for sure if they have these nuts but another source for mil-spec hardware here in the states is the Bon Aero division of Dave Bean. The link is at the bottom of their main page.
http://www.davebean.com/
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
+1 on McMaster Carr, pretty much sourced all the bolts and fasteners I needed on my S4 rebuild. Plus if you put the order in early enough, you get it the next day, The only problem I have is always forgetting something I should have ordered after pressing the confirm button lol.
- gearbox
Just going through old Threads looking for some thing else but just seen this one.
I had a problem with the right Nuts too but a friend owns a Triumph Motorbike main dealer, he told me those 1/2 Unf T-Type nuts are commonly used on old Triumph motorbikes and are easy to get through Classic bike specialists.
These are the ones he supplied me (Centre) the Original one is Grey (right) and the last is a full nut (Left) for comparison.
The big washer that goes behind that nut is 1/2x1.25"
Grizzly - Coveted Fifth Gear
