lockheed servo
PostPost by: theelanman » Mon Aug 05, 2013 5:38 pm
anyone got a pic of he correct mounting orientation?
I would just like to check mine as its vertical.......and Im sure its not right......
thanks
Gareth
theelanman
PostPost by: mikec2126 » Mon Aug 05, 2013 6:58 pm
Hi Gareth
Please find attached all you need to sort it !
RemoteServo-fitting.pdf
Lockheed Servo
(1.1 MiB) Downloaded 646 times
I had a problem with my Europa S2 I bought as part completed project that had a Lockheed fitted horizontally and was giving problems bleeding my system. Also make sure you remove the air valve (bullet shaped ) and red rubber grease it)
Good luck
mikec2126
New-tral
PostPost by: Lotus fan » Mon Aug 05, 2013 10:15 pm
Hello Gareth.
Here's how I've installed mine.
Dunno if it works yet though !!
Ian F.
12-12-12.jpg and
Lotus fan
PostPost by: theelanman » Tue Aug 06, 2013 5:47 am
Lotus fan wrote:Hello Gareth.
Ian F.
just in time for the gold cup then
:mrgreen:
theelanman
PostPost by: theelanman » Tue Aug 06, 2013 5:50 am
mikec2126 wrote:Hi Gareth
Good luck
that's excellent......I thought it was too vertical.....my last +2 had it in the orientation specified.....this one isn't and the brakes just feel a little sticky....despite having stripped them down and checked them......
will play with the mounting bracket
thanks
Gareth
theelanman
PostPost by: mikec2126 » Tue Aug 06, 2013 9:13 am
Sounds like the little air valve Gareth - my brakes were sticking, can be sometimes tricky to prise out, I just used the pedal to pump it out into a bag, clean and rubber grease it.
Mike -
Good luck
thanks
Gareth
mikec2126
New-tral
PostPost by: theelanman » Tue Aug 06, 2013 10:00 am
mikec2126 wrote:Sounds like the little air valve Gareth - my brakes were sticking, can be sometimes tricky to prise out, I just used the pedal to pump it out into a bag, clean and rubber grease it.
I think I'll try to rotate the servo first....
currently its at 90deg to the ground and the valve rather than being at 5 o'clock (assuming the end elevation as a clock face)...mine is at 12 o'clock
I hope gravity may help....:-)
Gareth
theelanman
PostPost by: archigator » Wed Aug 07, 2013 10:58 am
I agree with greasing the piston in the servo, but be careful not to pinch the rubber diaphragm when you reassemble. (Don't ask why I know that...)
http://landcrabs.proboards.com/index.cgi?board=tech&action=display&thread=393
Gary
'71 Sprint FHC
Miami, Florida
archigator
PostPost by: Pistacchio sprint 72 » Wed Aug 07, 2013 11:32 am
Lockheed replacement servo at sjsportscars is worth 146 pounds. I looked at the picture and it seems like a complete package...
I looked into your thread with the dissasembly / cleaning / assembly procedure... well well , I know how clumsy I can be and I think I'd better spare some sweat, tears, and some horrible names/words by purchasing a new one....
Sad there is not a small hole where a simple drop of oil could solve the problem without taking everything apart.... :mrgreen:
I will replace mine for sure
Cooled down by CliveyBoy!
PostPost by: theelanman » Wed Aug 07, 2013 12:03 pm
think I may just get the spec of Johns spring.... :mrgreen:
theelanman
PostPost by: theelanman » Fri Aug 09, 2013 9:00 am
found this......
lotus-chassis-f36/top-tip-trash-idea-t25823.html
indicated source of the spring...:-)
theelanman
