Spring Compressor Front Plus 2
Mike,
As you suggest, at the top of the damper you need some hooks to pull the spring on the first coil.
Here's a pic of what I use. Hmmm, not quite as substantial as yours.
You do need to make sure the hooks cannot slip off the spring!!!!
- elanman999
O.K...........finally got one done. Had to do more fabing up of some steel. Thank goodness for Oxy/Acetylene and a nice Victor welding set..........turn and burn..............
Now I never need to depend on someone else to mount new springs. Also safe as can be. Since I have the shock inside the spring I don't need to weld in safety cups for the spring to sit in on the 1/2" plate.
Thanks all for the tips and pictures.
John, I stole your idea and incorporated it into my compressor so there is no way the spring can come out and kill me
mike
mike
"Be Polite, Be Professional, But have a plan to kill everyone you meet"
General "Mad Dog" James Mattis United States Marines
- cal44
I took my front dampers to the workshop at work. Two guys struggled, customised, fabricated etc and managed to get one spring apart.... They returned a the pile of bits to me shaking their heads....
So I went home and did this
Compressed the springs with straps. Took out the old damper and put in new protech adjustable.
Job done. 30 minutes !
LaikaTheDog - Third Gear
Snap-on internal compressor OK on standard springs, I use this in combination with the external threaded type.
Or External type provided there is space beside the spring
LOTUS Evora 400
Ginetta G27 S2
66 one-off 2.6Ltr v8 Mid-engine Berlinetta Coupe........... in restoration
..................................................Age doesn't matter unless you are a cheese................................................
Ginetta G27 S2
- au-yt
