Ok I've had it. I need professional HELP... Ride height
Just spent (wasted) 3 days chasing a lop sided elan. I really don't want to re-live the pain, so I will pass on the details and get to the point. I need a good suspension setup guy in So California that can fit adjustable perches & springs to the 'rear' of my elan. I need them to fit the parts, set up all the steering geometry, and do the corner weights. I'm usually a pretty patient person and can work these things out, however this has beaten me.
Recommendations ppppppplease
James
James
welllll I always thought the spring rate was such to compensate for the drivers weight ---mine leans high to the driver side so when my old fat body gets on board the chassis goes to level ----ed
I can't provide a measurement for that right now, but what I can say is that measuring the sills (both front and back, and both side) is a good way to check. Another thread mentioned that they should be 6 inches at all four locations. Mine were about 1/2 inch low in front and once I raised it up, the steering felt much less heavy, nice and light and responsive as I remembered it. Mine is more like 5 1/2 inches in all four locations due to lower profile tires than stock. Dan
I would have thought that the most important factor is to have the correct suspension geometry so ride height is dependent on tyre size and, to an extent, inflation.
'67 S3 SE FHC
'67 S3 SE FHC
