Trunnion repair kits?
Hi All,
I'm tightening the front suspension and notice that the trunnions are loose on the bolts. I have replaced the 2 plastic bushes and the steel tube.
On close inspection the tube that goes through the 2 plastic bushes is just some rough bit of pipe whereas the one removed is ground.
The old tube is a good fit to the bolt, but the new one is loose
Does this matter?
Have I bought the wrong kit? (the new ones have white plastic)
I have to take it all to bits as I have read in the archive that I haven't screwed the trunnion on enough!
Simon
Does this matter?
Simon
- AHM
Hi, not talking from elan experience on this, but i believe these are the same as fitted to the triumph heralds and gt6/spitfires.
I have assembled a few of those trunnions over the years, ( approx 8 pairs ) and i remember the nylon was always tight to fit in the trunnion sometimes requiring a slight ream to fit the steel tube !
The steel tubes i fitted in the past looked to be ground, and i believe latter ones became available in stainless, i remember the bolts were a easy but not lose fit in the tube.
when all is tightened up the steel tube is held tight between the wishbones, and its the tube that rotates in the nylon bush as the suspension moves up and down.
A rough outer surface of the tube would cause quick wear of the nylon !
I would recommend re-using your old tube if its not rusted, and make sure all steel sealing washers and seals are fitted, i used to apply silicon grease to lubicate but mostly to stop water ingress.
Brett
Brett
- brettfcars
The tube should be a snug fit on the bolt, so if you can I would reuse the original tube with the new bushes; and don't forget to copperslip the bolt and tube to prevent you having to take the angle grinder to the trunnion to get the bolt out at a future date! Another thing to replace is the top seal (the little rubber seal at the top of the trunnion) , which usually doesn't come with the trunion kits I've had, but is available - use Triumph Spitfire ones from Rimmer Bros. I always user gear oil in my trunions rather than grease....
Visit me on matthewvale.com
Matt Elan - Fourth Gear
Matt,
Old tubes are too rusted, so I have had to use the new tubes, which I hope will be ok as they are supposed to be clamped (see above) by the bolt rather than bear on the bolt - I'll keep a close eye and report back if they are no good.
I can't say I'm impressed but if they work, they work.
Seals are new
I allways use grease in mine! . . . Discuss! (no second thought don't)
Simon
Seals are new
Simon
- AHM
Hi folk -ref the 'new' tubes - I guess you should be OK! As for the use of EP90 its whats recommended by Triumph and Lotus, even in the Elite (M50) which I'm just getting on the road before I start on my Elan I accedently bought once I had the Elite on the drive.... These Loti come in packs you know!
Not sure replying to an 8 year old post will get any attention, but I?ll try it rather than create yet another trunion post.
How do you get the old trunion kit out? The trunion itself looks like brass and I don?t want to damage it.
Tony
1967 Elan S3 SE
Northeast US
1967 Elan S3 SE
Northeast US
- Tmac897
Presumably you're talking about getting the plastic bushes out of the brass trunnion? They're split bushes that go in from each side so once you've removed the steel tube you can tap them out by getting a screwdriver or similar into the small gap where they meet. Tap around the gap from both sides and they usually come out. Easier if the trunnion is on the bench rather than on the car.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
tcsoar wrote:Welcome to the forum Matt but WOW your first post and you end it with "I always user gear oil in my trunions rather than grease...."
Am I missing something? A joke maybe? Matt has been a member for 8 years and 270+ posts.
It?s gone over my head.
elanfan1 - Coveted Fifth Gear
elanfan1 wrote:tcsoar wrote:Welcome to the forum Matt but WOW your first post and you end it with "I always user gear oil in my trunions rather than grease...."
The post you're referring to was made back in December 2011, when Matt was a new member...
draenog - Third Gear
