rear shocks
I am sure they will Gerald. The only difference really 'tween the Elan and +2 is the body and a slightly longer chassis.
I would buy them! If they are what you want.
Good luck.
Alex B....
Good luck.
Alex B....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Gerald,
In case you missed it...something to be aware of: The interface with your Lotocones.
This thread gives the info ref top nut location/spacer issue.
post148923.html
Cheers - Richard
post148923.html
Cheers - Richard
- ardee_selby
Be careful with second hand shocks Gerald. Ask a few questions. You would not replace Konis with anything else as they are the best, so why were they removed?
I had a set of them on one of my Elans for 25 years. They were on the car when I bought it. But 2 years ago, one side sprang a leak from the top seal, leaked oil, so just replaced with a set of new ones. Point is, they still worked fine.
You would not be able to tell from the sellers pics or description if they are any good. He does not show the rods extended to see if there are any wear marks on them. Also, a good test is to leave the rods pulled out from the body for 24 hours. If they stay put, then all is well, if they drop back into the body, they are knacked, imho.
Leslie
Leslie
- 512BB
''Knacked'' Great word Leslie.... says it all..
Good advice bud..
Al '.....
Good advice bud..
Al '.....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Hi again,
thanks for the info, I'am assuming that they are very weak, cause when i'm driving she very noisy at the rear, and when i push down on the two rear corners theres a clunk as she hits the bottom of the downward thrust. The shocks look as if they have been on her from new, so 41 yrs old. All bushes are o k and all nuts are tight.
thanks again for your help.
Gerald.
S4 70 DHC OEW.
Gerald.
S4 70 DHC OEW.
- kerryblu
Gerald are you sure the clunk is the shock hitting the bottom!! It could be the special threaded nut in the tube, which secures the shock in the chapman strut not tightened enough!!!!!! Just a thought
Alan B
Alan B
- alan.barker
Surely both shocks would not be "knacked" at the same time. The shock on the nearside gets the most hamering, near the pavement and drainholes
Alan B
Alan B
- alan.barker
Gerald,
they should fit but I doubt they would work for an S4. The damping rates are set to match the weight and spring settings (and geometry and wheel/tyre weight etc. etc.) and the +2 and S4 are very different. They will probably be far too stiff for the S4..
Koni dampers are quality items and can be rebuilt (refurbished) so they may be a good buy for someone with a +2.
- mikealdren
mikealdren wrote:Gerald, they should fit but I doubt they would work for an S4. The damping rates are set to match the weight and spring settings (and geometry and wheel/tyre weight etc. etc.) and the +2 and S4 are very different. They will probably be far too stiff for the S4..Mike
Does that equally apply to the early adjustable versions? (I've always thought that because they were adjustable they could suit either vehicle )
But, originally, my S3 had Koni inserts and were far too stiff, IMO, even on softest setting. The ears had taken a real hammering as a result and looked very much like this, only worse, and I blamed the dampers:
Maybe +2 rated ones had been fitted...?
Cheers - Richard
- ardee_selby
Not sure whether the Elan Konis cover both, mine were not adjustable.
There is quite a big weight difference between the S4 and the +2 and I would have thought it would be outside the range of adjustables but I may well be wrong.
- mikealdren
