Tracking
Dear All
With all this talk of adjustable A frames,I thought I'd look into the tracking for the Plus2 and this is what I'm assuming.....
Front track 54"
Rear track 55"
Wheelbase 96"
From the manual,front toe-in 0 to 3/16" in total measured at the wheel rims....
From another manual,rears toe in 0 to 3/16" each side....
So if we go for middle ground and assume 1/16" toe-in on both front and rear wheels we end up with what appears to be a Trapezoid which I think looks quite stable?
And my old method of measuring/checking wheel alignment with a piece of string may not be all that far from accurate?
If anyone out there has their old Trig Tables I'm sure it could be worked out more accurately
Front track 54"
Rear track 55"
Wheelbase 96"
Brian (friend)
Don't really have one....just thought some mathematician may come up with more accurate figures,some people may want to set up their tracking with a piece of string,others may chirp in with "what a load of nonsense"...others may come to the same conclusion??
Hi Guys
If the wheels where aligned to a straight edge on a car with 55" rear track and 54" front track and a 96" wheel base you would get a rear toe in of a tad (2.5 thou) over 1/32" measured from the wheel centre to wheel rim compared to the car centre line and a front toe in of approx 1/16" again a tad over (+ 5 thou), measured wheel to wheel.
(Thats how I spend a boring five minutes during lunch!)
All the best Andy
All the best Andy
andyhodg - Third Gear
Andy
Isn't " 1/32" measured from the wheel centre to wheel rim".....the same as..." 1/16" measured wheel to wheel."...?
For added accuracy, use a reel of teeth floss, not string! It does actually pull straighter and tighter too.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
......too late,have my fishing line out...
