Front suspension assembly
I am in the process of assembling the front suspension. I have a square section O ring about 2 inch diameter which I remember fitted into one of the recesses in the casting which holds the brake caliper when I took the assembly apart, but cannot remember which side! I have a exploded view of the GT6 MK3 assembly and sure enough the seal is shown between the upright and the caliper casting. However, I would have thought the casting would bolt directly onto the upright, it fits together snugly and there is no need for a seal there anyway.
I cannot see the seal shown on the elan workshop manual, and I cannot see what use this seal is anyway? Could it sit outside of the felt hub seal or on the hub?
Thanks for any help.
David
David
- davidj
I have to say I've never seen the point of a seal there.
If you look at the exploded diagram of the corresponding Herald item (see here: http://www.rimmerbros.co.uk/Item--i-GRID005374) then there is no seal - hence none on the Elan originally. Triumph seem to have introduced it for the 6-cylinder cars with the larger caliper plate (like this, presumably the same diagram as you're looking at: http://www.rimmerbros.co.uk/Item--i-GRID008048).
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Yup you are right. That is the diagram I am looking at. Well spotted. The seal is part 138051. ( What is 138559?) I thought the Elan +2 used the GT6 front suspension? Certainly the caliper plate and upright on my car are similar to http://www.rimmerbros.co.uk/Item--i-GRID008048, The caliper plate is round rather than square.
Anyone else have this version of the suspension and an idea where the seal should go or even if it is required?
David
David
- davidj
I think TeeJay is correct; the ID of the washer is the same as the OD of the felt seal, so I think it fits over the felt seal up against the outer side of the break caliper mounting (unlike the exploded diagram, where it is shown on the inner side!)
Thanks for your help, David
- davidj
The rubber seal goes between the upright and the caliper mount bracket in the recess in the bracket. The felt seal is fitted so that the felt rubs on the upright ie facing away from the bearing.
regards
regards
_________________
1969 ELAN PLUS 2S
1998 CATERHAM 7 SUPERSPORT
1969 ELAN PLUS 2S
- elan_fan
Now I am confused! The upright has a boss which fits into the recess in the caliper mount bracket. If the rubber seal was in the recess, the bracket would not be flush onto the upright but held proud by the seal. And why do you need a seal between these two parts anyway? However, the seal does fit rather neatly into the recess!
Anyone else care to comment? I would not normally say this but I guess in this instance it cannot be that important as it would appear most owners do not even have the seal fitted!
David
David
- davidj
I assembled the suspension with the O ring in the caliper mounting plate recess, upright side, as suggested by the "team" and it all went together OK. Thanks for your help.
The car sailed through the MOT so another +2 is back on the road in West Yorkshire!
Ride height is a bit high, but I think that is the subject of another post.......
David
David
- davidj
