hammer for knockons
1kg hammer, have a look at the one Frost sells:
http://www.frost.co.uk/item_Detail.asp? ... &subCatID=
Or I am pretty sure Machine Mart on North Station Road would have one.
Jason
Jason
Jason1 - Coveted Fifth Gear
I use a double ended Thor type hammer, aluminium insert one end and hard plastic the other. This seems to work well as I use the plastic end first and then give about four good whacks (technical term) with the ally side. This gets the spinner tight without damage. I think I bought it in B&Q.
I have tried rubber mallets before but personally I didn't feel they were too effective
Ron
50/0775
Ron
50/0775
- rong
Do I have to assume that the hammers are are certified as calibrated to obtain the correct 210 lbsf ft torque?
I use Sarto's excellent device: http://knockoffspinnertool.com/products
However, there is an alternative: http://www.spinitoff.com/
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
If you are wanting to hit the spinners then a Lead or Copper mallett is best. The reason being when you hit with either lead or copper the strike is a dead blow and you dont get any recoil or bouncing back of the mallett. If you use rubber or hide you cant get as much force with each strike also more risk of recoiling and damaging body work etc.
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
cliveyboy wrote:If you are wanting to hit the spinners then a Lead or Copper mallett is best. The reason being when you hit with either lead or copper the strike is a dead blow and you dont get any recoil or bouncing back of the mallett. If you use rubber or hide you cant get as much force with each strike also more risk of recoiling and damaging body work etc.
Clive
2nd'ed
Beware of the Illuminati
I've also used a cabinetmaker's dead blow hammer. This tool uses a shot=filled head that absorbs the impact and reduces or eliminates bounceback.
The advantage is that it has a soft face since it's intended for use on wood and won't mar the spinners.. The disadvantage is that it's a bit more fragile than the metal ones and not quite as heavy.
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
I use the original lead hammer and a nice block of mahogany - works OK.
I have also been advised that automotive dead blow hammers as sold by Snap-On and others work well.
I like the idea of the posh Sarto Spin it Off type tools but there is always something more important to spend the money on - hopefully the wheels don't need to come off too often anyway.
[quote="nebogipfel"]I use the original lead hammer and a nice block of mahogany - works OK.
Hey John,
that's what I call adding a bit of Class; "a nice block of mahogany".
Joking aside my ol' Dad used same for various jobs because it's a nice solid lump of wood well capable of transfering the "shock"
Exits stage left
Hey John,
Exits stage left
