Front damper replacement
Due to the small spring size regular off the shelf spring compressors will not work. I have been told that a motor bike service shop may be able to help as the front damper/spring unit from the Elan is similar to a bike rear unit. Alternatively you will have to make up your own compressor device from some threaded rod and bars.
steveww - Coveted Fifth Gear
HardTop wrote: how to compress the front springs so as to replace the damper
See this thread
http://www.lotuselan.net/forums/viewtopic.php?p=61305
Not having much in the way of machine shop facilities at my disposal, I simply used three nylon web clamps with ratchet mechanisms. they cost a few dollars each at the hardware store. I strung them through the coils and tightened the ratchets alternately until the spring had decompressed enough. Cheap and quick
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
I am with Art on this one.
Just get some ratchet straps and they slide between the spring and the body. Ratched them down bit at a time and bob's your uncle.
No machining, minimum cost (I had mine lying in the garage) and work on any 1.9 inch set up
Bruce Crowthorne - Third Gear
