rear suspension damping
there are limits to load capacity of these cars affecting the handling ---perhaps you have surpassed them ----ed
I have not measured the springs yet but I think the suspension travel has become less restrictive since I have changed form the donuts to a full C.V. solid drive shaft setup and therefore a need for a slightly stiffer spring???
However at the end of the day you have to test drive the car in order to find out of changes you have made work or not and in my case I am very happy with the outcome.
Next time I would take the suspension apart I would consider making the suspension fully adjustable but for the interim this works just fine.
Robin
Robin
- bengalcharlie
Simple, economical change => problem fixed =>
A good outcome in Lotus-land.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
MintSprint wrote:Be careful!!
Elans/Plus 2's do tend to feel a little soft and under-damped at the rear end.
Increasing roll resistance at one end of a car - either by fitting stiffer springs or by fitting an anti-roll bar (AKA sway bar, for our american cousins) increases weight transfer at that corner, which consequently decreases the grip.
In other words, increasing front roll resistance tends to increase understeer, whilst increasing rear roll resistance (as you are suggesting) tends to increase oversteer, which is not a good thing!
I hope I remember my physics correctly - surely fitting stiifer springs or an anti-roll bar will DECREASE weight transfer at the corner concerned. This then agrees with the results mentioned in this thread whereby increased stiffness at the front promotes understeer and increased roll stiffness at the rear promotes oversteer (aka "drifting" in modernspeak!).
It's not a rehearsal
- Gopherit
