small or large front upright?
Hi Bob
All knock on uprights used the larger GT6 uprights, stub shafts
Bolt on wheels used the early spitfire equivelents.
The stub axles are 5/8"and 1 inch in diameter on the spitfire/bolt-on hubs The stub axles are 3/4" and 1.060" on the GT6/knock-on
Gary
Gary
Hi Bob
Inner and out bearings are different as well as the Hubs (Elan and
Plus 2 knock-on hubs are also different),stub axles and uprights. It would be easier for a upright assembly to be swapped onto a bolt on wheel car than a knock-on wheel vehicle but that doesn't mean much to the average Lotus home/pro mechanic. If it can be done wrong, it may very well be done wrong...
Gary
Gary
Front Suspension 1967 S3 coupe
Can you visually tell the difference between an upright for a bolt-on axle from an upright for a knock-on axle if no axle is fitted?
I would hate to take mine apart, including removing the axles from the old uprights only to find that I had got the wrong new uprights.
It is possible to do the full GT6 conversion to bigger bolt on hubs / bearings / axles / uprights...I have done this (part by error, then by design).
I have just one suggestion: whilst this works for Girling AR calipers (alignment) i have not tried it with the original calipers...
Is it possible to spot...no, IMHO.
- Frogelan
vxah wrote:Outside stub hole measures about 27.5mm on the big upright and small upright is about 26mm.
Inner hole size is 21.5 for big upright and 20mm for smaller upright.
Are these for bolt-on axle stubs or for knock-on axle stubs ?
Users browsing this forum: Elanman68 and 19 guests
