Removing a Trunnion with a siezed Bolt.
PostPost by: Matt Elan » Sun Mar 06, 2022 7:05 pm
You may be lucky using heat on the ends of the bolt but you need a lot of heat to break the bond between the bolt and the bush. Doing heat will eventually burn out the nylon top hat bushes. When I had this problem many years ago on my spitfire there was one solution. Use a thin cutting disc or hacksaw to cut the bolt and bush between the wishbone and the trunnion - there is just enough space in the ‘rim’ of the top hat bushes to do this without damaging the wishbone or trunnion.
If you’ve used heat and burnt out the bushes it can be a bit easier to get the saw onto the bolt and bush.
Visit me on matthewvale.com
Matt Elan
PostPost by: tonyabacus » Mon Mar 07, 2022 4:57 pm
Bill
Having checked on my spare chassis I concur with what Snowyelan is saying.
Snowyelan, I have sent you a PM
Tony
tonyabacus
Previous
Users browsing this forum: gjz30075 and 33 guests
