Rear A-arm geometry...
Hi All,
Are there geometry specs for the rear A-arms? I am guessing that the two axes (inner and outer) should be exactly parallel. I have been checking mine.
If I place the A-arm on my lathe's bedways, I can precisely measure the relative level of the outer end compared to the inner end. The bedways are very close to level -- more importantly, I know exactly how far they are from level (right now .005" per foot) (I'm making new lathe feet, so I haven't chased it beyond eliminating bedway twist -- and it's not necessary for lathe accuracy).
The passenger side A-arm from my car is out from parallel by .095" or 2.41mm (at the inner mounts). So, toed in... That's a .095" gage pin in the photo (not a guage pin here, weirdy). This A-arm has a little bit of jack damage to the inner longitudinal. That toe-in sounds about right doesn't it? Obviously it needs to be checked once assembled, but I'm trying to save time by identifying bad A-arms.
My spare is dead nuts perfect -- and is damage-free.
Are the inner mounting points on the chassis parallel to the centre line?
Am I barking up the right tree?
Thanks.
Thanks.
1964 Elan 1600 #3370
- Brock
Yeah... Good question. I'm taking back my guess. It makes more sense that it comes from the A-arms... but I'm not guessing.
* It just dawned on me that there no such thing as a passenger or driver's side A-arm... They're the same... just flipped.
- Brock
