Lotus Elan Sprint Fuel Filter
Stiil trying to sort out my misfire so in following advice from you chaps was checking the earth strap in the boot.
Low & behold I found an in line fuel filter installed in the 6 inch rubber hose coming out of the tank which looked full of dirt.
I tried to get a replacement from Susan Miller but she says they weren't fitted as standard equipment. Has anyone else got one in their Sprint and I presume a standard 2 quid plastic replacement from Halfords should do. I'd rather not remove it altogether even if it isn't standard, as I'd rather have muck trapped in there than get to the Dellortos.
Thanks in anticipation.
- andrewdmoore
I installed one at the same location as yours is installed, but to protect my electric fuel pump as well as the carbs. As it is on the suction side I too used a plastic bodied one from my local parts store. It is nice to be able to see if anything has collected.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
