Fuel Gauge/handbrake Light
Hello All!
My petrol gauge never shows more than half full when the tank is entirely full (makes long journeys to airshows a bit of a lottery!) and my handbrake light seems to suit itself as to whether or not it works (this month it says "No!"). As for the oil gauge...don't even get me started..... :blink:
Any pearls of wisdom?
Many thanks!
Many thanks!
- flyingvee
I don't know about +2s but on my Elan the pin in the switch was really gunked up. If yours is the same clean it with some solvent (beware of plastic) and re-lube it.
Mike Geiger
66 S3 Coupe'
Mike Geiger
66 S3 Coupe'
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
Just might be a poor earth from the instruments. They all earth to the bolt that holds the body to the chassis, on the right hand side of the transmission tunnel just behind the dash. I had instruments that pleased themselves when they worked and what they said. Fixing the earth fixed the problems. One added symptom on my S130 +2 was that when the headlights were switched on aqll the readings changed and when switched off they changed back again.
Just a thought.
Just a thought.
Roy Gillett - Second Gear
