Choke cable swop
What do you need a Choke cable for. Never used one in 50 years
- alan.barker
I have changed inner choke cable and knob on my car without a problem. Just make sure the end of the new cable is not frayed in any way otherwise it can be difficult to slide it in without catching.
Skittle. 1967 Elan S3 DHC
- skelteanema
alan.barker wrote:What do you need a Choke cable for. Never used one in 50 years
Ha! That's funny, Alan, different horses for different courses.
I use my choke/starter circuit every time I start the car from cold. I do it because it works flawlessly (don't touch the accelerator!) and I like to keep all the parts moving rather than doing nothing and potentially gumming up with our ethanol laced fuel.
Anyway, the Heath Robinson/Rube Goldberg mechanism appeals to me. It's too wonky to ignore!
Nick
elanner - Fourth Gear
skelteanema wrote:I have changed inner choke cable and knob on my car without a problem. Just make sure the end of the new cable is not frayed in any way otherwise it can be difficult to slide it in without catching.
Hello did you change the cable and knob as a unit or were you able to attach a new inner cable to the existing knob?
Paul
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
pcarew - Second Gear
Hi Paul - Thanks for asking.
The answer is No atm - Like many projects, one thing leads to another……
The carbs came off & I decided to fit new 151’s as the cost wasn’t much more than rebuild quotes. I had a devil’s own job getting the ram pipes out of the original 31’s to release the airbox backplate. The previous owner had liberally applied sealant to seal the back of the airbox and a minute amount had squeezed around the pipes creating a strong bond.
Finally got the old carbs apart this weekend. I’ll be putting the new carbs on after powder coating the backplate. I’ll then look again at the choke cable and make a call on how to approach this.
- Cadence
Hi Paul,
I replaced the cable and knob as a unit. My car had the incorrect knob when I purchased the car. I managed to find a cable/knob unit from an Anglia (I think) that was correct and I swapped them over as a single piece..
- skelteanema
Users browsing this forum: joe7 and 13 guests
