Huco Fuel pump
PostPost by: alfadave » Tue Apr 23, 2024 8:42 am
Has anyone used a genuine Huco 133010 electric fuel pump?
German made, pull type, 120 litres/hr
Used to be listed by Webcon, but no longer it seems.
alfadave
PostPost by: JonB » Tue Apr 23, 2024 9:13 am
Yes. I had it in my Plus 2 S130/5 with twin Dellortos and it was very good. Quiet, too. You could hear it when you turned the ignition on, just, then when it stopped you knew the carbs were primed. After all the cold cranking effort previous to the install, having the car start first time everytime was a huge relief.
I discussed it in this thread: viewtopic.php?t=46315&p=332391
PostPost by: alfadave » Tue Apr 23, 2024 10:43 am
Thanks for that.
Just a couple of points from your previous thread.
Huco say the pump should be mounted horizontally.
The 133010 is a pull pump. Engine comp.
The 133000 is a push pump. Boot mounted.
Not sure what exactly the difference is though!
I too am tired of cold cranking after lay up. And sucking fuel through.
What ever happened to pump cranking levers I used to have on my A35.?
alfadave
PostPost by: cliveyboy » Tue Apr 23, 2024 11:18 am
I have a Huco pump on my Sprint and very happy with it.
Its a push one that generates about 2psi. It sits in the boot at the back next to the tank.
I also wired it up to an inertia switch to shut it off in an accident.
Clive
1972 Elan Sprint FHC
cliveyboy
PostPost by: smo17003 » Tue Apr 23, 2024 12:49 pm
I also have the 133000 mounted next to the fuel tank in my S4. I would say that it works perfectly.
As I would like to do the same with my S3 I have just given Gower and Lee a call (they supplied the previous one). Unfortunately they have no stock of any of the Huco pumps, saying that there is a problem in sourcing them.
I see that there are some on Ebay, but located in Latvia. Not a risk that I'm prepared to take.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: pharriso » Tue Apr 23, 2024 1:00 pm
smo17003 wrote:I see that there are some on Ebay, but located in Latvia. Not a risk that I'm prepared to take.
That's where mine came from, delivery was prompt... no issues.
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: smo17003 » Tue Apr 23, 2024 1:11 pm
Hmmm, thanks Phil, perhaps I should reconsider. I won't be needing one for a while, so I'll see how it goes regarding UK stock over the next few months.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: alfadave » Tue Apr 23, 2024 1:20 pm
Try Fast Road Cars in South Wales
alfadave
PostPost by: smo17003 » Tue Apr 23, 2024 1:31 pm
alfadave wrote:Try Fast Road Cars in South Wales
Just tried them. Nil stock, and he doesn't think they're available in the UK (he actually said "not available anymore in the UK").
Looks like Latvia it is, or perhaps an alternative pressure type pump.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: RichardS » Tue Apr 23, 2024 7:38 pm
Funnily enough I have been looking for this Huco pump this week to no avail (apart from the Latvian and Polish EBay items which I guess would be subject to tax and delivery is about 4 weeks). One of the suppliers said that they no longer supply them as Brexit has introduced too much red tape.
Lotus Elan Sprint FHC 1973
RichardS
PostPost by: alfadave » Wed Apr 24, 2024 8:30 am
I have bought from Latvia and Poland via Ebay before without problem.
Carriage cost is more of course.
But delivery was prompt, and no taxes to pay.
Ebay would reimburse you if anything went wrong.
There still seem to be UK sellers on Ebay with Huco pumps though.
alfadave
PostPost by: Barney » Wed Apr 24, 2024 5:11 pm
Keep it simple.
Why not use an aspirator bulb from an Outboard Engine Fuel Tank?
Elan S2 DHC (26-4399),
Barney
PostPost by: alan.barker » Thu Apr 25, 2024 8:15 pm
alfadave wrote:Thanks for that.
Please show me where Huco say it should be mounted horizontal.
PostPost by: alanr » Fri Apr 26, 2024 3:56 am
This company selling the Huco 133010 say it must be mounted horizontally
See here:-
https://fastroadcars.co.uk/store/index. ... duct_id=92
Alan.
'71 +2 S130/ 5speed Type9.
PostPost by: alan.barker » Fri Apr 26, 2024 4:44 am
Thanks Alan,
Strange they say this because Webcom don't nor do Huco. I think they are wrong and getting mixed with the old S U Pump which had Points and different. Many problems with S U Pump fitted to a 1071 Austin Cooper S on rear Sub Frame exposed to the elements.
I have a Huco Pump in the boot of my TVR 3000S and boot of my TVR 3000M. They are both vertical and no problems for the last 7 years. Lots of Kms driven no problem at all.
Easy to fit and Inlet and Outlet can be orientated to install very neatly.
Personal choice i suppose.
Next
Users browsing this forum: pcarew and 32 guests
