Lotus Elan
Road draft tube on S3
PostPost by: gjz30075 » Wed Nov 08, 2023 3:28 pm
Sort of following up on my continuing air box questions, my car 45/7286 has a road draft tube but
also has a rounded back plate with a nipple for a breather to go to the head. Which would be correct:
road draft tube or tube from back plate to head?
Or maybe both, assuming 'overlap' with parts?
This thread could be helpful but the pics are gone. Has anyone saved the pictures from this thread?
viewtopic.php?f=40&t=19248
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: StressCraxx » Wed Nov 08, 2023 5:42 pm
It could have been either one, but most likely the breather tube to the road. The parts book indicates the tube to the airbox started with the Strombergs. I converted mine to the tube to airbox because I got tired of the fumes and vapor coming from under the car when sitting in traffic.
BTW, my chassis # is 7279.
StressCraxx
PostPost by: alan.barker » Wed Nov 08, 2023 7:31 pm
Vocab English or USA draft or draught.
But what's a Draught/Draft tube please.
PostPost by: RichardHawkins » Wed Nov 08, 2023 7:44 pm
Alan,
My understanding is that a draft tube is a piece of pipe that vents crankcase fumes to atmosphere under the car. My car is an early S4 1968 and came with a draft tube.
Richard Hawkins
RichardHawkins
PostPost by: StressCraxx » Wed Nov 08, 2023 7:46 pm
alan.barker wrote:Vocab English or USA draft or draught.
Hello Alan,
My humble skills with translating American caused me to think he was referring to the breather tube hole at the back of the head that had a rubber 90 deg elbow to a metal tube that allowed the crankcase fumes to escape out the bottom of the engine bay.
StressCraxx
PostPost by: gjz30075 » Wed Nov 08, 2023 7:55 pm
^^^ Correct.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: alan.barker » Wed Nov 08, 2023 8:18 pm
Ok so 2 different spellings possible.
For sure breathing in Engine vapours or Exhaust is not nice.
PostPost by: pharriso » Wed Nov 08, 2023 11:30 pm
Also referred to as a Road Oiler!
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: prezoom » Thu Nov 09, 2023 3:02 pm
Chassis/subframe saver.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: Quart Meg Miles » Fri Nov 10, 2023 3:34 pm
Has anyone designed a catch-can or bottle to collect the fluids from that tube?
Since rebuilding my engine with a proper rear crank seal I only have oil drips from the tube after a run, quite small but worth keeping off the floor.
Meg
Quart Meg Miles
PostPost by: Foxie » Thu Dec 07, 2023 11:29 pm
Quart Meg Miles wrote:Has anyone designed a catch-can or bottle to collect the fluids from that tube?
Before I converted my Plus 2 to dry-sump, I took a 500 ml brake fluid bottle, stuffed it with pot scourers to catch the oil, cut a hole near the top to take a hose from a nipple which I tapped into the head breather opening. I emptied the bottle when it was full.
68 Elan +2, 70 Elan +2s
PostPost by: Quart Meg Miles » Thu Dec 07, 2023 11:57 pm
Before I converted my Plus 2 to dry-sump, I took a 500 ml brake fluid bottle, stuffed it with pot scourers to catch the oil, cut a hole near the top to take a hose from a nipple which I tapped into the head breather opening. I emptied the bottle when it was full. :)
Thanks Foxie, I hadn't thought of replacing the original tube! I know the +2 has more space (and yours being LH drive doesn't have the brake cylinders on the carb side) but I'm wondering where your bottle vents to, is it up with the carbs or down below?
Meg
Quart Meg Miles
