Stromberg suction chamber screw specs?
I have Stromberg 175 CD2 carbs in my +2, and the screws on the top of each carb are pretty worn and a couple are close to stripping. I took one of the screws to my local home center to check the threads, and so far as I can tell they are M5-0.8, and 14mm long. Most stuff on a Lotus is SAE/Imperial, so I was a little surprised to find these appearing to be metric based on my fit test in the store.
So I got some new screws (stainless), and did another visual check comparing the threads. But when I put them in they'll engage the first 3-4mm of thread but then start to get quite tight, and I stopped as I was worried I was cross-threading. I tried several holes, all the same.
Anyone able to confirm the spec? Was I just being too cautious? I didn't apply any grease to the threads initially but I could also try that.
- Richardsona39
I'm also looking for a definitive spec for these screws. Mine are rusted and one has nearly lost its "cross drive" recess, so is tricky to tighten / loosen.
By the way, I would expect them to be UNC (coarse) threads as they are screwing into aluminium. But happy to be proven wrong.
(Edit: Thought I'd do a search and found an alternative to Burlen who appear to sell more than just overhaul kits: http://www.gowerlee.dircon.co.uk/Stromberg.html.)
(Edit 2: Found an expensive set on eBay: https://www.ebay.co.uk/itm/151555997139.)
JonB - Coveted Fifth Gear
Thanks all, very helpful. I'll see what I can source locally (I'm in US) - can always go for McMaster Carr if I don't mind paying several multiples of the item cost for shipping
- Richardsona39
If they are 10/32UNF and about 14mm long and look like JONBs picture
I would search for 10/32 x 9/16" UNF cheese head screws. These will give you a screwdriver slot
Some one said they had lost there "cross drive" If that means you need philips, pozidrive/superdrive heads then search for pan head screws
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
Yep, got exactly as suggested from Home Depot - did have to order them as they didn't have the 9/16" in my local store, they should arrive in the next few days and I'll give them a go.
- Richardsona39
Richardsona39 wrote:Yep, got exactly as suggested from Home Depot - did have to order them as they didn't have the 9/16" in my local store, they should arrive in the next few days and I'll give them a go.
My experience is that the hw section in Lowe's is better than home depot. Somewhere like Ace hardware is probably even better.
- mbell
mbell wrote:My experience is that the hw section in Lowe's is better than home depot. Somewhere like Ace hardware is probably even better.
Exactly true in my experience as well.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Just a follow-up to confirm that #10-32 UNF and 5/8" length are the correct fit - just installed them this morning.
- Richardsona39
