Installing Stromberg carbs
PostPost by: Wayne » Sun Aug 13, 2023 5:48 pm
Question, is it better to install the o-ring adapters to the carbs first before the carb install? Looks easier that way.
Wayne
Wayne
First Gear
First Gear
PostPost by: david.g.chapman » Sun Aug 13, 2023 6:16 pm
I cheat by fixing each o-ring to the intake manifold with three drops of super glue. Then you know they are in place as you tighten up the carbs.
If you take things apart in future the super glue comes off easily enough.
Dave Chapman.
david.g.chapman
PostPost by: SENC » Mon Aug 14, 2023 11:32 am
I use EZ Turn fuel lube to do the same.
Henry
69 Elan S4
65 Seven S2
PostPost by: 69S4 » Mon Aug 14, 2023 12:32 pm
I've always fixed them to the manifold with a smear of grease. When you put the carbs on the studs you can easily see if they're still in place.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: snowyelan » Tue Aug 15, 2023 1:23 am
To answer your question, yes put the adapters in the carbs first.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: Wayne » Tue Aug 15, 2023 8:06 pm
snowyelan wrote:To answer your question, yes put the adapters in the carbs first.
Thanks, If I remember correctly that's how I took them off. I rebuilt the carbs, bolted the carbs to the adapters and then installed the carb adapter/combo onto the manifold. I used a skim of Pliobond to hold the o-ring in place. The rear lower adapter nut was easy to install, once I jacked the engine up a bit for more clearance to the body.
Wayne
Wayne
First Gear
First Gear
PostPost by: Wayne » Tue Aug 22, 2023 10:25 pm
Pretty happy with the install so far. Carbs were running lean, so I raised my non adjustable needles and it now runs much better, but still slightly lean at idle. I had rebuilt my carbs with the jets installed at .097" to the center of the jets. I will now use my Volvo jet tool to lower the jets to about .115 " and see how the engine runs. I might have to lower the needles back to flush in the piston.
Wayne
First Gear
First Gear
Users browsing this forum: GLB and 45 guests
