Stromberg carburettor choke/cold start device
Having just bought an S4 SE Elan, I was surprised that the car would start without using the choke. Also, I had noticed that the car was running rich. When I bought the car, I thought that the mixture needed adjusting, but if course, the Strombergs have a "fixed" main jet. Removed the carbs, checked the needles and main jet heights, all correct. Further investigation revealed that the Cold Start "discs" had been fitted 180' out of place. Re-assembled and refitted the carbs, mixture is now correct, and choke is needed to start the car. Unfortunately, the choke cable is only attached to the front carb, so I'll see how well it works before connecting the rear carb Cold Start device.
This is all "just for information", hopefully it will help someone
Atb, Phil.
Atb, Phil.
- Philturn
Very easy to do, especially if you’ve had the carbs apart and left it a while before reassembling them
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Certainly helps me, thanks Phil!
JonB - Coveted Fifth Gear
1 should be plenty for getting it started, mine is that way as well.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
My late 72 build +2S130/5 has the two Strombergs with only the choke on the front carb and I’m not sure what the crossover point was but it has the adjustable needles so I guess yours is just before that, Gordon
- Gordon Sauer
Hi Gordon, my car also has the adjustable floating needles, but they are very much a "trimming" tool, as the range of movement is very small. Any major mixture adjustment would involve altering the jet heights .
Atb, Phil.
Atb, Phil.
- Philturn
Even the 'non-adjustable' needles are actually adjustable to a very small degree, just not as precisely. If you loosen the lock-screw on the needle you can move it up or down a hair or so.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
