Improved Weber linkage
I’m not impressed with the standard throttle cable linkage to my Weber’s in my early plus 2. There seem to be plenty of options that look much better engineered but they all seem to be for two throttle cables. Has anyone located a linkage similar to the two cable ones provided by people such as Burton or Kelvedon, but with one cable?
- Bigbaldybloke
Check the one that 1Owner69 has
Also Sabbot made for his +2, though on Stromberg
Love your Mother
Earth
Love your Mother
Earth
h20hamelan wrote:Check the one that 1Owner69 has
I have the same one and have put perhaps a week's worth of hours fiddling, cutting, fabbing, fussing, to finally get something that seems acceptable. So I caution anyone about that design. Yet, do not let me speak for 1Owner69--perhaps he will chime in on this. If my eyes do not deceive me he may have done at least a little fiddling with it. John
- baileyman
I used the TTR dual line
i too used some time. I am very happy, smooth and yes it does open fully.
Love your Mother
Earth
Love your Mother
Earth
The Magoletsi one is a proper engineering job with adustments for travel and gearing. I took a digital TTR one off to fit one.
Available in both single and dual cable.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Lots of useful suggestions, but another question from me, how are the two cable kits installed at the pedal end. Does it involve removing the pedal box and modifying it?
I really don’t want to have to strip this out again, I’m trying to go forward with the rebuild not back, I’ve been at it now since 1986 and the end is in sight if I don’t keep undoing work I’ve already done!
- Bigbaldybloke
I didn’t need to strip mine, had to drill a hole through body beside the other hole.
As I recall, the pedal was easy.
Love your Mother
Earth
Love your Mother
Earth
Bigbaldybloke wrote:Lots of useful suggestions, but another question from me, how are the two cable kits installed at the pedal end. Does it involve removing the pedal box and modifying it?
I had to fabricate a small T peice for on the pedal side for the 2 wires.
- Terry Posma
Decision made, I’ve ordered a Mangoletsi single cable kit. From the comments made I’m aware it may take a bit of fettling to get it installed but happy enough to do that. Didn’t feel the need for a dual cable setup as it’s only for road use. Thanks all for the feedback.
PS big differences in price of the kit, one supplier was over double that of the one I bought which was not from a recognised Lotus parts supplier. Will post pictures when it’s all installed and working.
- Bigbaldybloke
I don’t know if you saw my earlier post on the Mangoletsi on a Weber Elan. But, it may answer some of the questions on a way to make it work without modifying the head inlet webs.
viewtopic.php?f=40&t=48415&p=350519&hilit=+Mangoletsi+you#p350519
I still prefer the Mangoletsi to the TTR system, but the TTR is certainly more readily installed. The Mangoletsi allows me to drive with regular shoes as I have it adjusted so I don’t have to push the pedal that far to achieve WOT. But, still can modulate the pedal for lesser throttle positions.
I believe any of the dual cable systems (Mangoletsi, TTR, ..) will work with one cable. I really didn’t see the need to bother with dual cables . I thought it highly unlikely that the single cable is going to snap.
Perhaps in a racing situation with abusive WOT on/off driving wherein the cable is repeatedly over tensioned? But, my cable never gets into that over-tensioned state. Much neater with one cable and less complication.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Thanks, I did read your post and the detail in it convinced me that going the Mangoletsi route was the way to go as the problem areas were known and the fixes well detailed. I’ve never seen a manufacturer fit dual cables so with the limited mileage I will be doing single cable was a no brainer.
- Bigbaldybloke
Good decision. I have a Zetec Elan with 180 plus bhp and it was difficult to drive in the wet or damp with the TTR one. The Mangoletsi one even has a spare little bushes pack and Allen key. The adjustment is great allowing you to have a longer progressive pedal to drive with more finesse. Only down side is it helps you find any little of slow running jet stumble in the acceleration.
I lost my mech' when I went to bike carbs but managed to bring back my pedal stroke by mods to the pedal fulcrum point through the fibre glass and on the anchor point. Also being a bike set up having a return cable mech', I added a second cable and sping loading to get a very nice controllable pedal that comes back to closed properly.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Bigbaldybloke wrote:Thanks, I did read your post and the detail in it convinced me that going the Mangoletsi route was the way to go as the problem areas were known and the fixes well detailed. I’ve never seen a manufacturer fit dual cables so with the limited mileage I will be doing single cable was a no brainer.
I have never understood the 'twin throttle cable' business. It always seemed like a failure of design if two cables were needed. I am sure Colin wouldn't have approved.
I have the TTR mechanism on the Elan I race(d). It is built like a brick outhouse, and IMO not very elegant. I ended up chopping bits of unnecessary metal off the main support bracket, mainly because it looked so bad. I raced using it with a single cable, and have never had an issue.
On my roadgoing Elan, I have a 'Timavo' linkage which I think is a far better design. Unfortunately Timavo are long gone, but there are CAD files of the design for anyone who wants to give it a go.
https://grabcad.com/library/timavo-linkage-for-weber-dcoe-carburettor-1
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I added 3 areas of reinforcement, plate below and above where wire goes through body and 2 stanctions off thermostat housing.
This takes the flex out, straight run from thermostat and dual lines with the provided strong springs works great!
Mine is smooth
Mine is smooth
Love your Mother
Earth
Love your Mother
Earth
