Petrol tank, correct for an S1?
I'm trying to determine whether the currently installed petrol tank is the correct type for a Series 1 Elan (dispatched Oct. 1963). One item which looks odd to me is the venting tube on the filler next. This tube is currently sealed so not providing any venting. I had thought the petrol cap, being a vented type, was to serve the venting requirements. If this is the correct tank for a Series 1, what is the purpose of the two threaded bolts, horizontally facing, on the side facing towards the right rear fender? Thank you for your inputs.
- 1963 S1
Might be for a much later car because I think the two threaded bolts on the side held
the charcoal cannister, for emissions control. Just guessing here. But it doesn't mean
it won't work on your S1, or any Elan for that matter.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
My early 64 has none of those items on its tank, it was however and Australian delivered car. Is it possible this a tank is from later Elan from period they fitted Strombergs and smog gear, I seem to recollect there was a canister fitted to catch the fumes....
V
V
- vstibbard
Greg Z is on the right track; you have a Petrol tank from a late Federal S4 or Sprint that was fitted with a catch tank in conjunction with other emissions equipment.
Here's a picture from the parts manual on RDent's website:
There is no downside in using this tank instead of an original tank as long as the vent is blocked off.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
