Weber 40 DCOE OEM type carb Lotus lever cable barrel
I am updating my webers with some new parts . Just wanted to know if the Lotus lever cable barrel is in the correct position. I would assume so because wire throttle spring protects the Lotus lever cable barrel opening the way it looks..The car is RHD..
Lou
Lou
Louis Lottner
Elan S2 1965 #26-4840
Colin Chapman’s immortal words ‘Simplify, then add lightness’
loueelotus - Second Gear
I don't see the throttle return spring, though I do see the hole through which the end fits.
RogerFrench - Fourth Gear
Thanks for the answers.. all together now and ready to start her up as soon as the weather warms up in the great white north
Lou
Lou
Louis Lottner
I've always fitted mine the other way round so it is much easier to disconnect the cable: just depress the lever and lift out the sleeve followed by the wire's bullet from the bracket below.
One annoyance I used to have was the bullet finding it's way out of the bracket while adjusting things so I trap it with the spring. It's easy to slide the spring sideways to release it again.
Meg
