Dellorto throttle
I was mounting the throttle spring to my plus 2 dellortos. I have a pair of 45 dellorto in my plus 2. I think I don’t have the correct throotle lever.
- Dieschelan
I can fit the spring because there isn’t enough space...
Can someone put pictures of dellortos ...
Diego
Diego
- Dieschelan
Hi Diego looks like the correct spring this is a photo of mine when i removed the carbs it might help if you need more let me know
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
George S L wrote:Hi Diego looks like the correct spring this is a photo of mine when i removed the carbs it might help if you need more let me know
Thank you for the picture. The problem is that if I put the spring (the lever is near to the carb bolt and can touch. See the picture:
- Dieschelan
Another question is the correct position of the spring. I think in the Webber carburation is different. Should the spring goes in the air filter zone or next to the cylinder head?
- Dieschelan
It looks like you have the spring in the wrong way, turn the spring so that the coil is towards the air intake side .
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
If you look at my photo you can see the spring is the facing the other way
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
Hello, mine looks like this
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
