Stomberg mixture puzzle
There are too many things going on here to rationally figure out what is causing rich mixture on a car that reportedly runs well
On CD2SE carbs one can adjust the mixture by removing the pistons, loosening the setscrew and sliding the needle up and down then tightening
Other things that can affect mixture
oil in dampers
what springs are in the carbs
are the temperature compensators working
First I would buy Lotus needles, changing to some unknown needle can have unknown consequences
B1Y B1AR or maybe some others. I think B1G was the emissions needle
oil in dampers
- gus
We went on a drive yesterday, about 325 miles. Oil was topped up when we started, it looks now like it's down about 40% of a quart, which works out to about 1 qt every 800 miles.
And attached are shots of the plugs after that drive.
2,3 and 4 look pretty good. Maybe appear to be a bit on the rich side, but the car ran great, started easily when hot - I'm not going to complain. #1 is a bit oily, so it looks like that's where the oil is going - rings or guides, I don't know.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
Hi Steve,
Both of your pics of No. 1 plug seems to show an oil deposit, more so on the second pic after that long run. I an sure you have checked that it is not unburnt fuel, as it would evaporate after a few mins, and there is no misfiring.
Incidentally your cylinder 2 and 3 pics are the same, so I am assuming both plugs look like the pic shown.
It might be worth checking the compressions again and posting the figures after this run for comment. Anything less than 160psi for a low compression Federal head of maybe a bit more for a high compression head would confirm a problem, especially if the other cylinder compressions were more than 10% higher.
Then I suppose its head and sump off time to measure bores, look for broken piston rings and check on valve guide clearances. . Or live with it for now.... Unless someone has any other thoughts?
Dave Chapman.
Dave Chapman.
- david.g.chapman
Compression #'s:
Cyl Dry Wet
1 165 170
2 155 165
3 170 190
4 175 175
I did my best to use the same process on all the cylinders - I couldn't exactly measure the amount of oil in each, but they all got three pumps of my oil can, which should be about a tbsp, maybe a bit more.
155 to 175 is too wide a variance by a bit - I've always heard 10%, and that's about 13%. And I have no clue why #4's results are the same, wet or dry, other than the rings seal great, and they can't get any better? Or why #3 is pretty good to begin with, but then goes way up - maybe the chamber is just smaller, and the rings are so-so?
In any event, any oil getting into #1 is likely coming down the guides, correct?
The collective's thoughts?
And Dave - thanks for the catch. Here's the correct pic for #2.
Cyl Dry Wet
1 165 170
2 155 165
3 170 190
4 175 175
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
gus wrote:A guide losing that much oil would be pretty thrashed.
It occurs to me that the high pressure oil feed is adjacent to the #1 cylinder
Try a leakdown test
Not fun but a bad head gasket is better than a head rebuild.
We may have a winner.
Before a 740 mi road trip, I put in new plugs. The engine used a qt of oil. This is how they look after getting back. Left to right: 4,3,2,1:
I took a wifi bore scope and took a peak into each cylinder.
Here's #4:
Here's #3:
Here's #2:
And here's #1:
Which looks wet and oily to me, where 2,3,4 didn't. So, Gus, I'm thinking you called it.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
