Throttle pedal travel
Thanks again guys.
Yes, cut and weld I guess, sadly I don't have welding kit or skill so I'll have to farm it out.
Graeme - my original lever gives 5 inches of travel which is very long compared with my other non Lotus classic cars. I'm sure it is as original, but I think the travel was originally made long as standard because of the Rotaflex couplings and their tendency to surge. As I have CV joint driveshafts I'd like a sharper throttle response, hence the search for a shorter lever.
Vernon
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
There you go, had a dig around in the loft.
Apologies, it's 45mm, which is about 1 and 3/4 " for those in the colonies.
This is the Syvecs throttle linkage. I have the TTR one too but preferred the action and angles of the cables of this one.
https://youtu.be/l-M7W9B5Nfo
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
An alternative would be move the point that the throttle cable connects to the throttle pedal closer to the pivot point which led have the same effect. It would require an additional hole to be drilled in the top of the foot well to allow a direct action.
V
V
- vstibbard
