Throttle pedal travel
My type 26 Elan has the original 40 DCOE 18 Webers. I've always found the throttle pedal travel very long and find that in normal driving I frequently fail to open the throttle fully when accelerating. I've measured the pedal movement and it takes 5 inches of travel to reach full throttle; this compares with 3.5 inches on my 1974 Alfa saloon, and 3 inches on my Westfield Seven. Presumably this long pedal travel was adopted to help avoid drive line surge with Rotaflex couplings. As I have CV jointed driveshafts I've been toying with the idea of making up a shorter carb throttle lever, thinking that this might give the car a more responsive feel. As it is, it feels less responsive to the throttle than my crossflow engined Westfield which has similar power, although the Westie is lighter of course.
I think this is probably a silly idea, but would appreciate your thoughts.
Vernon
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
I did this a few months ago and I prefer it. I took around 7mm out of the throttle lever on the carb by cutting it and welding it back together.
I also made sure to fit the throttle pedal stop that was missing (I have a +2 not sure if elan have them.)
I think Lotus might have done a similair mod back in the factory as I believe the cars came with shorter throttle lever:
viewtopic.php?t=33943&f=40&start=0#p230264
- mbell
mbell wrote:I did this a few months ago and I prefer it. I took around 7mm out of the throttle lever on the carb by cutting it and welding it back together.
Very interesting post. Mbell - can you give any info on the throttle pedal stop for +2, as I'm sure I don't have one. Can't find it in the Parts Manual or the suppliers.
- andywatts
andywatts wrote:mbell wrote:I did this a few months ago and I prefer it. I took around 7mm out of the throttle lever on the carb by cutting it and welding it back together.
The throttle pedal stop is normally just a bolt on the underside of the pedal it's the same on the two seater Elan and Plus 2
S4 DHC
S4 DHC
- oldelanman
I'm sorry I can't measure the distance again for you as the car is at the painters, but I did measure this a coupe of months ago as I was dry building the type 26.
If I recall ( and the synapses ain't firing like they used to) it was a 69mm full throw from open to closed.
Have a look at your carb end throttle linkage. Perhaps the arm on it is a bit long??
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
quaybook wrote:Hi
Vernon
Hi Vernon
Me too found ever the throttle pedal travel very long.
A very long time I have need to create a solution for my self.
What one can see on the picture is a transmission ratio from 1: 1.25. See the different in outside diameters.
The force is transmitted in the same ratio. Thats better for the springs in the carbs.
It should only a inspiration to be for any solution.
It's very good to handel. I will never to do without it. It's very comfortable now.
And all holes in the head and camcover (stromberg) have preexisted.
Cheers Urs
ElanDNA - Second Gear
Thanks everybody.
I'd like to fit a shorter carb throttle lever but can't find anything available other than what appears to be the standard one (part no 4504800700). Maybe I'll follow Mbell and try shortening one. I don't have welding equipment so I'll have to make sure I do a proper job that can't fail under load or, worse still, jam!
Urs, your solution is so inventive, I think it is great, but beyond my powers to replicate. I also want to keep the underbonnet look of my S2 as near original as possible.
Vernon
Vernon
Elan S2 26/5614
Westfield 7SE
Westfield 7SE
- quaybook
Urs,
Beautiful work. I have not seen a cam cover like that with Lotus on a yellow background, I rather like it.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Graham Arnold used to say that all engines hard a series of variables and all they used to do was ensure that all the tolerances were in the 'right' direction - not cheating as sooner or later an engine with performance would have come off the production line!!
- MarkDa
Presumably you've compared yours to the Burton ones?
https://www.burtonpower.com/parts-by-ca ... -kits.html
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Thanks Graeme. They Burton ones look the same length as mine I am afraid. I've ordered one and will check out properly when it arrives, but expect that I'll have to try to shorten it. The question now is how to shorten in a safe and reliable way.
Vernon
Vernon
Elan S2 26/5614
Westfield 7SE
Westfield 7SE
- quaybook
As far as I know only one length is available. Cut and weld is I think the only real option.
I have also found the spring hole on new lever toi small for the (replacement) return spring and needs drilling out. Drilling this out push the metal into the cable connection and that needs cleaning up.
They are also plated, so technically need replating.
- mbell
