Stromberg throttle cable
PostPost by: lotusbc » Tue May 26, 2020 5:32 pm
I have an S4 with Strombergs that the po installed, they are the high balance pipe type. My question is how to secure the throttle cable at the carb end. The po had clamped a small bracket to the balance pipe with hose clamps. I'd like to do something better that looks 'right' . In the attached photo you can get an idea what I'm trying to improve.
elan8.jpg and
lotusbc
First Gear
First Gear
PostPost by: 69S4 » Tue May 26, 2020 6:13 pm
It’s because you don’t have the Stromberg version cam cover. That one has a flat area machined about half way down the inlet side where the cable outer is located. The inner then continues down to the throttle spindle.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: Evante » Tue May 26, 2020 10:45 pm
Here is an elegant solution.
Jay S.
1972 Federal Sprint, Colorado Orange/White
2005 Elise, sold
1988 Evante 140TC, sold
Evante
One more.
Jay S.
2005 Elise, sold
Evante
PostPost by: velo5338 » Wed May 27, 2020 5:13 pm
Here's the solution with the proper Stromberg cam cover.
IMG_1046.jpg and
velo5338
PostPost by: RogerFrench » Thu May 28, 2020 11:31 am
Evante wrote:One more.
These are the high-specification Strombergs. :-)
RogerFrench
PostPost by: 661 » Thu May 28, 2020 11:43 am
My solution
IMG_1120.JPG and
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: lotusbc » Thu May 28, 2020 1:49 pm
The original plan was to drill a couple of holes and fit a simple bracket, but I'm hesitant. Is there a downside to drilling holes in the cam cover? In the correct cover are holes threaded or is the bracket affixed with bolts and nuts? The installations pictured look good. I'd have to replace the carb mounting bolts to fix anything as they are too short.
lotusbc
First Gear
First Gear
PostPost by: 69S4 » Thu May 28, 2020 1:55 pm
The Stromberg cover is thicker in the area where the bracket sits and the screw holes are tapped into the metal. The Weber ones are too thin to do that so it would have to be a bracket fixed to the sealing bolts - like 661's - or similar using the manifold bolts. Doesn't look that difficult to do either though.
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: oldelanman » Thu May 28, 2020 2:54 pm
The threads are tapped into blind bosses cast into the cover.
Accelerator cable bracket bosses 002.jpg and
A good many engines have been converted from Stromberg to Weber heads over the years .. maybe somebody has a Stromberg cam cover they would swap with your Weber one ? Try posting in the Wanted section on here.
S4 DHC
PostPost by: Evante » Thu May 28, 2020 10:26 pm
He is a throttle cable bracket that I build myself. It was a first try, and after I am done with some other fixes, I will go back and make another that looks a little more elegant. It was done with aluminum stock, aluminum weld, and a propane torch. Here is a link for low temperature aluminum welding: https://www.youtube.com/watch?v=jtvOkI_pvMI
IMG_1403.jpg and
Jay S.
2005 Elise, sold
Evante
PostPost by: h20hamelan » Fri Jan 01, 2021 5:47 am
Anyone know the source to purchase, or are they standard bike cables?
Thought they were thicker?
Love your Mother
Earth
PostPost by: h20hamelan » Sat Jan 02, 2021 3:23 am
Maybe a standard bike cable with a washer over the end
Are throttle cables on the elan not thicker?
Love your Mother
Earth
PostPost by: 69S4 » Sat Jan 02, 2021 10:47 am
The inner wire on my throttle cable is 1.50mm. I doubt it's the original but its been on there for so long I can't ever remember changing it. 1.50mm is a standard size for many bicycle and motorcycle applications and you can buy the inner on its own for around £1.50/ metre (ie very cheap). Not sure who you'd get it from in the US but I've used these people in the UK a number of times when I make up motorcycle cables -
https://www.venhill.co.uk/cables-and-co ... trand.html
The pedal end has a nipple soldered on it (which is slightly tricky to do if you don't have the bits) but the carb end uses a screw on type fixing. Mine looks like it was home made by a previous owner (it's secure but doesn't fit very well (so I suppose it could be Lotus!)).
Anyone have a picture of what the original Lotus Stromberg carb end cable fixing looks like?
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: oldelanman » Sat Jan 02, 2021 12:26 pm
Is this what you need or do you mean the bracket on the cam cover ? I have a drawing of that if needed.
PXL_20210102_121240852.jpg and
PXL_20210102_121228582.jpg and
S4 DHC
Next
cron
