Could someone double check me on fuel tank set up?
Hello and Happy Monday.
I have an aftermarket alloy fuel tank that came with my car. It has a female feed on the bottom, and one on the top left as shown in the attached picture.
There is not a pipe or line from the top left as shown to the bottom of the tank, meaning there isn't a way of using the top fitting to draw fuel out.
That has be thinking I should use the bottom fitting to capture the fuel from the bottom of the tank to and filter and then use an electric pump to then feed it to the OEM fuel line in the top center of the trunk.
Sound right? Thanks.
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
The bottom fitting is more likely for draining the tank for service. If you use a bottom of tank port for the fuel to the carbs, you will be sucking any and all sediment/debris present in the tank. Better to use the side fitting for the fuel supply.
Contact the maker (Axminster Panels) for their solution.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I have an Axminster tank like yours but the fuel take off is the same as the stock tank. I didn't check that the tube extended to the bottom of the tank, assuming it was OK. And it is, it works fine.
The plug at the bottom is for drainage.
I am sure that Andy (Axminster) can explain what was intended on your tank. Maybe a fitting with a plunge pipe extending to the bottom.
http://axminsterspecialistpanels.com/contact/
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Thank you for the responses. My tank is similar but is not one of his tanks, those were the clearest shots I could find of a similar set up. His work looks excellent.
Here is a shot of my tank, does not appear to be any connection / pipe on the inside which is why I was thinking bottom opening.
Agree that it is not an ideal place to have the fuel pick up (but my TR4A does it that way).
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
Does that threaded fitting near the top of the tank have an internal tube to near the bottom.
Then it would work as the original system.
If not then the tank has been incorrectly made.
I believe there is a requirement that fuel has to be drawn from the top of the tank so that if the car and tank are inverted and the fuel pipe severed, then fuel does not run out. The pick up pipe would then be in air inside.
It would be dangerous to draw fuel from the bottom.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Thank you for the discussion. I am working off a disassembled car, with some non-stock parts, and this is my first Lotus so I appreciate the patience and support while I learn.
I will get pictures of the tank posted shortly, still a bit early here in California.
This tank has a three stud mounting set up.
I cannot see a hose or pipe inside that opening I posted, there is an open space behind it and what looks like a baffle.
Eric - not arguing but curious why a bottom pick up would be unsafe?
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
I am not so sure about the details, it is just something I heard. It may also be that if the fuel pipe is damaged, with a bottom outlet on the tank it would empty onto the road whereas with a top outlet it is less likely.
I can see that in some vehicles it could still siphon out, but that doesn`t make it a bad idea.
looking forward to hearing what you find.
Eric
Eric
- ericbushby
A suggestion for a possible solution, find out the thread type in the top hole, go to your local plumbing store and pick up some 1/4 copper pipe and try to find a swage/thread fitting similar to the picture below. Pict. is 3/8 parts but similar type parts available for 1/4 pipe. Bend the pipe about 90 deg. and to suitable length so end just off the bottom and with some finesse fit in the tank with some pipe extended of course past the swage. I suggest wrapping the fitting into the alum. tank with teflon tape, as brass and alum. like to seize together. (eg. the diff. plug!)
( I have used teflon on the bottom plug on gas tanks and seems impervious to gas.)
Oh, .. if there is a flanged stop for the pipe you may need to drill out the flange stop to pipe dia. to enable pushing the pipe all the way through.
Jack
Jack
- jk952
jk952 wrote:Hope you can find suitable bits. I just had my original tank out to replace the sender; can’t say placing the sender mid height and inaccessible was Lotus’ better idea...lol...
Hope things are well in SoCal.
Jack
I was thinking the same thing! Seems like a leak waiting to happen.
Doing OK down here, it's been hard on the kids having to be separated from their friends. Hope all is well up North Jack.
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
So that there is no misunderstanding, the picture of the fuel tank shown at the top of this thread is of one of the tanks that I have made, but the issue stated and the pictures shown later in the thread relate to a tank that I have definitely not made.
Many thanks,
Andy Wiltshire
Axminster Specialist Panels Ltd
Many thanks,
Andy Wiltshire
- Andy Wiltshire
Users browsing this forum: tonyabacus and 42 guests
