Strombergs - worn spindles
The carbs have an air leak, new gaskets didn't fix it and the spindles have a bit of wiggle in them so thinking its likely where the leak is.
I know they can be re-bushed with new spindles - is that a DIY job or do the carbs need to be sent away for machining & rebuilding?
Andy
Andy
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
- Andy Hamblin
There a good over view video on replacing the spindle/bearings:
https://www.youtube.com/watch?v=0udpHCOBihY
Older/original carbs have leather seals that can be replaced, new ones use sealed bearing.
- mbell
mbell wrote:There a good over view video on replacing the spindle/bearings:
thanks, but the vid is for Webbers, I've got Strombergs
- Andy Hamblin
Are the spindles worn, or just the seals? The latter is a very simple job.
Check out this page for great information on rebuilding Strombergs, including a way to upgrade with bearings.
https://www.buckeyetriumphs.org/carburetors
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
thanks to every one who posted. Just to let you know that I have sent them away to be fully rebuilt. They were untuneable and a bit of an unknown quantity anyway.
- Andy Hamblin
