DCOE 18 vs 27
While trying to tune my carbs I have just noticed after 3 years of ownership that I have different carbs mounted on 45/6646. The rear is a 40DCOE18 while the front is a 40DCOE27.
What is the difference? Does it represent different stock jetting?
Until recently the car ran well so I am only now trying to improve the tuning. I am wondering if during a rebuild the previous owner installed the 27 because that was what he could lay his hands on. Hopefully he re-jetted the carbs to match.
Any suggestions?
Any suggestions?
Don Fysh
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
- donselan
I am currently running 24's on my S2. Have sets of 18's and 31's, but the progression hole placement on the 24's seems to make for a better transition from the idle jets to the main jets, with less of a bog. The 152G (5 progression holes) carbs on the Zetec Plus2, work without any hesitation or bog. Keith's first gen VF tubes added a significant amount of poke over the original E tubes with the jetting I had worked out for the standard E tubes. Just installed his second gen VF tubes in the Elan, so Saturday will be the first real test of those tubes.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:I am currently running 24's on my S2. Have sets of 18's and 31's, but the progression hole placement on the 24's seems to make for a better transition from the idle jets to the main jets, with less of a bog. The 152G (5 progression holes) carbs on the Zetec Plus2, work without any hesitation or bog. Keith's first gen VF tubes added a significant amount of poke over the original E tubes with the jetting I had worked out for the standard E tubes. Just installed his second gen VF tubes in the Elan, so Saturday will be the first real test of those tubes.
At the end of a dyno session I've had a go at a set of later tubes from KF (AB tubes #4 he selected based on the description of the build) I had purchased this the summer, with the best settings I eventually retained for the engine (idle 40F8 main 135 air 180) and the outcome was lower by at least 5hp on the whole curve from 2000 on with respect to E16 emulsion tube, so did not push further.
I'd be interested in the outcome of your tests...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
As Jon suggests it's likely the top cover just got changed as it's quite common for the float pivot to break.
As already suggested check the progression holes are the same size / position, things like the breather hole is present in the front of the main body casting and of course the jet sizes are the same.
Grizzly - Coveted Fifth Gear
Thanks for all of the explanations and suggestions. I think it will be a winter project to compare progression holes size and position between the two carbs. I would love it if it turned out that they are the same and that it is only a replacement top cover.
Thanks again.
Thanks again.
Don Fysh
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
- donselan
Original specs for Alfa's with DCOE 27's.
And the pump strokes.
