Fuel banjos with Sytec linkage?
For the carb with the linkage i use an Aeroquip compression fitting for the weber ( FCM1067 , i think , but double check ) - I run a short section of - 6 braided hose terminated with a -6 female to a -6 male/male/male T . you have to notch the bracket to make it work. the rest of the loom can be done with press on fittings ( otiker clamps are optional with low pressure of needed for webers) with appropriate hose.
- cabc26b
