Fuel line from tank to carbs
Has anyone installed a fuel line through the frame without removing the body? How difficult is it? Are there another option for routing the line?
Also, I am considering installing a fuel cell rather than a stock tank. If you have done that, please let me know how you are running your fuel line and what type of line you are using.
Thank you, Joe
Thank you, Joe
- elaninfuture
Joe,
I replaced the original nylon line in one of my Elans years ago with another nylon line. Was a challenge, but by removing the right hand seat, lifting the carpet and removing the large body plug on the right hand side of the tunnel
I was able to snake it through the frame openings. If if remember correctly, there was a clip on the underside top of the frame tunnel that I bent down to remove the old line, then bent back up to hold the new one.
Don't forget to tape up or otherwise plug the new line to keep out the inevitable grunge.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I replaced the original nylon fuel line from the tank to the engine bay with stainless tubing of similar size with the body on (but engine/trans out). Fished the line from the tank location through the same body grommet at the back and then through the frame. Since the tubing is relatively rigid, not too hard to fish it to the front. Used p-clips to secure.
Felt that the stainless line would be more robust than the original nylon (which, however, had never failed in 49 years and still looked good).
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
I did mine twice , first time I used 8mm copper tube and found it too soft , it bent and kinked as I pushed it through the grommets , so second attempt I used 8mm kunifer pipe much better but still difficult to feed between the body and chassis at the rear , then slide through the grommets at the rear and front of the chassis
But doable
But doable
- Concrete-crusher
I have done this (+2 with Spyder chassis). Propshaft and diff were out, engine & gearbox in place.
I was able to feed a replacement (PTFE) pipe from the rear. I seem to remember there was a clip at the front that I eased with a screwdriver.
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Thanks for the tips. I think I'm going to go with stainless steel. Glad to hear that it can be done. Is there a preferred diameter for the line?
- elaninfuture
Here is the stainless line I used:
https://www.summitracing.com/parts/SUM-220214
0.25 inch OD
It straightens out readily from the coil that is delivered. It is a pretty straight run from the rear to the front. At the front I bent it upwards to connect to my carbs. I have an electric fuel pump in the rear. I used AN fittings throughout - no leaks.
I fed it from the rear without a lot of issue.
Good luck.
0.25 inch OD
Good luck.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
In my S3 Coupe, I fitted a kunifer (hard coppery) fuel line along the right hand side of the cabin, behind the trims and behind the sill zigzag strengtheners. It then enters the engine compartment near the carb airbox to a filer/ pressure-regulator, before going to the Dellortos..
Description and photos on my long topic, starting here:
lotus-elan-f19/getting-ogu-roadworthy-again-t26101-90.html#p178305
I fitted a braided line in my street elan after I installed a fuel pump in the trunk, to avoid the risk of the pump pushing the fuel through a damaged nylon line in case of a fire or accident. Like mentioned above, I remove the right hand seat to gain access to the transmission shaft tunnel and made a braket to attach it in that area. I also made a bracket to attach it to the chassis tunnel in front of the diff. I used a rubber protected clip to attach it to the frame when entering the bay area.
I left the original nylon line in place for the time being and reversibility (it is clipped on the chassis by small steel fasteners).
Not an pleasant job, even with a car lift (I crimped the carbs end of the braided line in situ to avoid removing the somewhat rigid braided line one more time and to avoid a larger hole in the trunk), but certainly doable.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Users browsing this forum: alan.barker and 13 guests
