Carburettor (weber) specialist
Hi, Live in Kingston, Surrey, looking for a carburettor specialist in this area.
Unless someone can help. Have totally rebuilt my S3 SE engine, and stripped and cleaned the carburettors today. I noticed that the carb operating no. 1&2 cylinder does not full open, it opens to aproximately 90%, it closes correctly, but is not in alignment to the other carb when it opens fully. It is not very often that I will be flooring the accelerator, the mechanism inside the carb works smoothly.
Any Ideas
sepans(Brian)
Any Ideas
sepans(Brian)
- sepans
Hi Brian,
Have you balanced your carbs with one of these? https://www.ebay.co.uk/itm/Carburettor- ... :rk:1:pf:0
Also is the throttle linkage stock?
Grizzly - Coveted Fifth Gear
I am guessing the engine is not running like that?
Sounds like the adjustment between both sides of the linkage is way out, would play havoc on partial throttle openings.
I seem to recall that each side has a clamp for the initial settings then the adjustment screw, its been a long time!
- Chancer
I knew Ian Smith (https://www.linkedin.com/in/ian-smith-1 ... bdomain=uk) when he was in Woking. He's now moved I think to Ascot but that page has his email. He is very much a Weber expert and I would definitely recommend him if he's still doing that work.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
