Access to O ring at rear Stromberg float bowl
PostPost by: bdea » Sun Aug 19, 2018 11:06 pm
Does anyone know if I can access the rear Stromberg Carburetor Jet Cover O ring without removing the Rear Carburetor from the manifold? I want to remove the plug w O ring and replace the O ring since it was weeping.
Can you detach the motor mounts and possibly the transmission mount, then lift the motor high enough for the bottom of the rear carb to clear the footwell and remove the Jet Cover on a LHD?
Another question is why the fuel pump is so close to the footwell, about 1/8" clearance? Failed motor mounts ?? About 28 years old, low mileage of course. Both motor mounts look the same, so no mix up as required for webers.
TIA!,
Brad
Jet Cover
20180819_1514531.jpg and
Stromberg Float Bowl
20180819_1515351.jpg and
Fuel Pump Clearance
20180819_1516221.jpg and
20180819_1517201.jpg and
Motor Mounts:
Left Mount
20180819_1613171.jpg and
Right Mount
20180819_1614001.jpg and
20180819_1614241.jpg and
bdea
First Gear
First Gear
PostPost by: saildrive2001 » Wed Aug 22, 2018 8:40 pm
I don't believe you can remove & replace it without removing the carb. If your car is LHD then you might be able to remove the rear carb but I haven't been able to do that without first removing the forward carb on my RHD car. The fuel pump is very close to the body I believe on all cars, it certainly is on mine but never hits the body.
Keith Marshall
saildrive2001
PostPost by: Phongsakorn » Wed Nov 14, 2018 4:16 am
I have tried this method to use it. Can be used really.
Phongsakorn
New-tral
